Introduction: 4 Paper Superhero Keychains
Crafty nerds assemble!
If you are a superhero fan like me, I have a cheap craft for you. Express your nerdiness with some paper keychains!
- thick cardboard
- thin cardboard
- scissors
- glue
- acrylic paint
- paintbrush
- map tack
- keychain or string
- pencil, ruler, round objects
- optional: file / sandpaper
Step 1: Paper Tips
- What kind of cardboard am I using?
Thick cardboard: can be found at the back of notepads, big calendars or in packaging
Thinner cardboard: from cereal boxes or similar packaging
Step 2: Green Lantern - and the Basics
I used round shaped objects and a ruler to draw the Green Lantern symbol. Then I cut it out with nail scissors (nail scissors are just the best!).
Additionally I cut out two more circles for the background.
To glue all the pieces together you can use a glue stick or a thin layer of liquid glue.
Before painting all of the keychains I poked a hole with a map tack.
Step 3: Painting (Method 1)
You can either glue the pieces together first and then paint, or paint and then glue.
With most of the keychains I went for a more distressed look. I glued first and gave everything a black basecoat with acrylic paint. Then I dry brushed more colors on.
Step 4: Batman
For the Batman symbol I freehanded 3 elliptical shapes that fit into each other.
Then I turned the smallest one into a bat. You can simplify the bat as much as you want to make cutting easier - the Batman symbol has so many variations anyways ;)
Step 5: Painting (Method 2)
This time I painted the pieces separately first and then glued them together. That way you get a neater look.
Step 6: Wonder Woman
For the Wonder Woman symbol, I drew 4 parallel lines and sketched out the rest looking at references.
Cut that out and glue it to your base - I made mine rectangular. The rectangle felt less sturdy than the circles from the other symbols, so I added more cardboard layers to make the piece stronger.
Here again I started off with black acrylic paint and dry brushed some gold and red on afterwards - being careful to keep the black gaps in the logo visible.
Step 7: Deadpool
The Deadpool symbol is probably the easiest one!
The base is a circle cut out of thick cardboard.
Then I cut out a smaller circle from thinner cardboard and cut two lines in the middle. Lastly you need to cut out the eyes.
Again I gave everything a black base coat and dry brushed red and white on afterwards.
Lastly all you have to do is to attach the pendants to a keychain!
Of course you can do whatever symbols you want using this technique - I hope this gave you some inspiration :)
Paper Contest
