Introduction: Metal Wall Art - Sailing Boats
I'm totally into Arts and Craft...anything interest me. I've been looking into metal art...but not being able to weld for lack of equipment was a major drawback...being surfing for a cheap welding kit...but all the prices were way... to high for me. Imagine my excitement when instructables put up this challenge...and the prizes!!! wow! My mouth is still drooling.....so please pretty please...VOTE FOR ME :-).
Below is my metal art....using soldering ....for those lucky once who have a welding kit....go ahead and weld...it's so much easier and better! I remember seeing something like this online while surfing for metal art...but i cant recall where.
Step 1: What You Need...
To color aluminium sheet...you are supposed to use patina for metal...now....i have never used it...so i went to the stores and asked for patina to color aluminium....I got a total blank look....i was offered putty! could be language problem...we do not speak English in my country...so maybe it's called something else...
Anyway....they probably thought i was bonkers...as women usually..... in my country......do not get into woodwork, metal work or any predominantly male work :-)...so I'm weird.
Basic materials you need:
Aluminum sheet
Black paint
hot glue gun
Strong wire...but you should be able to bend it when pressed real hard by hand
Oil based Wood stains (my alternative to patina)
Soldering iron and soldering wire
Some wires...to bind the strong wire( since the strong wire doesn't get soldered)..I used the wire from some of my old burnt up insulated wires
Step 2: Waves
Cut the wire into various length ranging from 30" to 36"...i cut 7. You could also cut all the same length and then trim them later...
according to your preference.
Bend the wire into waves...it doesn't have to be perfect.
Place one wire on another like in the picture and tie with a wire that can be soldered.
Build up the waves gradually by weaving some wires through others...tie certain places with the wire...( but keep in mind where you want the boats to be...so that you can tie where the boats are and then the connections won't be visible).
Once you are satisfied with your waves..solder where you have tied.
Now paint it Black...to give a wrought iron look.
Step 3: Boats
Print out the template ...re-size to the sizes you want....or Draw your boats on cardboard....place it on the waves...check if the proportions are satisfactory to you...I cut 2 large 2 Medium and 3 small boats.....later i thought 2 large and 1 medium and 4 small would have been ideal....but then again...i couldn't decide.
Place your templates on the aluminium sheet and trace and cut...mark them if you don't want to mix them up. Cut the mast from the wire and like in the waves...tie with a wire and solder...then paint it black.
Clean the aluminium cut pieces and stain them with wood stain...oil based is best...
I used Teak , mahargoney and ebony.
Once dry... varnish them ...Varnish the back too...it's easier for the next step.
Step 4: Assembling
Paint your wire strips black...or if you can find black wires (like pipe cleaners) that too is fine. Place it on the sails at the top and bottom and hot glue it....it would adhere better if the surface has a bit of varnish on them..so make sure to vanish the back too in the previous step.
put a bit of UHU glue or hot glue to the top of the mast and wrap the flag tightly around the mast. Next attach the boat. Finally attach the sails.
Place the waves on the floor and place your boats on it....You may follow the picture or place it anyway your heart desires :-)
Take a snap shot so you wont forget how it's placed.
Now remove the boats and slowly attach the back boats first to the waves with the black wire( twist it well)...attach where it's covered by the sails.
Pull the waves up a bit when you are attaching the front boats so it would be higher.
Step back...look and tweak the waves hear and there to give a better dimension.
Now nail your wall and hang your wall art :-D
Ta Da!
Metal Challenge
Make It Real Challenge
