Introduction: Building a Plastic Injection Mold - Lesson 1 of 10 Mold Making Basics
Basics: One of the most important parts of building a mold that is capable of making millions of part, is the mold design. In this instructable we will take look at the pig picture when designing and building molds. We will break down 10 future lessons into the following lessons.
  1. Part Design
  2. Plastic Selection
  3. Molding Machines - Plastic Processing
  4. Mold Styles & Costing
  5. Mold Cavity Splits & Shrinkage
  6. Cutters Methods Used Fabricate the Mold
  7. Mold Design
  8. CNC Programming Setting Up The Job
  9. Polishing & Fitting
  10. Debugging the Mold
Plastics are essentially squeezed into a chamber with a machine that takes small pellets and melts them before it is pushed into the cavity. Cooling is routed thru the mold to make the process run super fast. If you find that you need lots of parts, you can add multiple cavities or a pattern of cavities. One can imaging when plastic molecules are cooling, then tend to shrink from a liquid state to a solid state. Molds must accommodate for these changes, so the cavities and cores are scaled up so the plastic will shrink back to size. We will refer to this subject as shrinkage.
These cavities and cores are mounted in a mold base where small pins are used to knock the plastic parts out of a cavity or core. The core is traditionally on the "B" side of the mold. This is also refereed to as the ejector side of the mold. The cavity is on the "A" side of the mold or the hot side. That is the fixed and stationary in the molding machine when it is bolted down. We traditionally inject the plastic into this "A" side of the mold.
Step 1: Identify How Many Parts You Will Need Then Size the Mold and the Press
Here is an 16 cavity mold starting up. This mold will make 3.5M parts/month and run at a 12 second cycle time. We need to first understand how many parts are needed then we can figure out how many cavities and how big the mold and the molding press will need to be to satisfy those requirements.
Here is a Screencast on Mold Making Basics: http://autode.sk/1iSvdTO
Here is a Screencast on Mold Making Workflow: http://autode.sk/1FzM0VA
Step 2: Mold Cutting
When CAMing in Fusion 360 you need to start with large cutters, then work towards small cutters. It is important to not skip a step, or you will start breaking cutters. 1/2" Dia to 3/8" Dia. to 1/4" Dia to 1/8" Cutter to 1/16 Dia. " Cutter to 1/32" Dia. cutter. Remember, the deeper you cut with the smallest cutter it tends to break. So try to design your parts with the biggest radi in each corner.
Here is a screencast on CAMing: http://autode.sk/1KWAPXy
Step 3:
