Introduction: Chocolate Prank!
During weddings here, some of the groom's relatives would go to the bride's house the day before the wedding bearing gifts for the bride. Then again immediately after the wedding too the groom's relatives visit the bride's house. During this time usually simple and harmless pranks are played by the bride's side to the groom's visitors. The fun part is..the groom's side if caught in the prank would pretend not to be caught!
Some of the pranks have been so far to coat the edges of the drink glasses with chilli, or give a good dose of salt or chilli to beverages :-)
Well, this time I thought, how about paper chocolates?? Imagine them trying to gulp down paper! haha perhaps they would keep it in their mouth and slip it into their pockets?? What fun to observe ;-D
Step 1: Colors of Chocolate
Basically you need paper the colors of chocolate and all the essentials in crafting!
White chocolate color paper
Milk chocolate color paper
Dark chocolate color paper.
Paper shredder
Box cutter
Glue
Thin wire
scissor
quilling tool - optional. You can use a pin or tooth pick
For basic shapes please check this instructable
Now let's see how we are going to decorate are chocolates :-)
Step 2: Chocolate Sprinkles
To decorate cake, chocolate we use chocolate sprinkles, so how do we make paper sprinkles??
Using your box cutter cut your paper into 1mm thin strips.
Then using a thin wire begin by folding the top into a 45 degree angle and then twist your wire. For some it might take a bit of practice, but keep at it. You will get the hang of it soon.
Once you have formed the spiral in the wire, slip it off and if necessary twist by hand.
Make plenty of these spirals.
Then holding these spirals together snip away sprinkles with your scissor!
These looked so real that I had to get up and go have a chocolate.
WARNING THIS INSTRUCTABLE WILL PLAY HAVOC WITH YOUR DIET!!!
Step 3: Chocolate Curls
To make Chocolate Curls, Twist a strip of 1mm or 0.5mm (it's hard to cut 0.5 so just go as thin as possible) paper in a Quilling tool. Make 3-4 turns and cut off.
You could also just hold a bunch of strips together, cut off every 1/2" and then twist the strip with a pin. I found this method much quicker and easier.
Step 4: Milk Chocolate
Now for our first chocolate.
Cut a strip of milk chocolate paper about 30" long and 15mm wide. Roll it up and let it loose forming a loose circle. Now Glue.
Press and form the shape of a rectangle.
cover the shape with glue and cover it with chocolate sprinkles. You could leave it like this or you could also decorate it with a strip of dark chocolate spiral paper.
To decorate with dark chocolate spiral. Twist a 0.5mm strip to form a spiral. Dab glue at one end and glue under the chocolate. Now wrap up about 3 times like picture and glue it down. you could also strategically dab glue in the necessary places so that it will not move.
Want to eat it?? Me too!
Step 5: White Curl Chocolate
Cut white chocolate color paper in to a strip of 30" long 6mm wide.
Roll it up , glue and form a square shape.
Cover with glue and sprinkle ' White chocolate curls'.
Decorate as picture with Dark Chocolate spiral paper.
I soooooo want chocolate!!!
Step 6: Dark Chocolate Delight
For the dome shape use normal quilling strip width which is 1/8". Take a strip about 36" . Roll up to a tight circle. The size should be approximately 2.5 c.m. in diameter. Make 2. Dome one and keep other flat. Glue the dome to the flat tight circle.
To make the oval shape. Cut a strip of paper 6mm wide and 30" long. Roll up and form a loose circle and glue it down.
Now cover both shapes with glue and decorate with dark chocolate sprinkles.
For the dome I used milk chocolate spiral. Glue the tip of the spiral to the top and gradually form the shape of a spiral. Glue in place.
I decorated the oval in White chocolate strip.
Doesn't these look real?
Step 7: Milky White Dome
Using shredded paper or quilling strip of white chocolate make 2 tight circles to measure approximately 2.5 cm in diameter.
Add a milk chocolate strip to one circle. Dome the other circle and glue on top. Now apply dots of glue all over the white dome and milk chocolate. Pour your chocolate sprinkles on top.
Done.
Isn't it just adorable??
Step 8: Prank Time
Now for the prank. Make assorted chocolates. Then mix them up with real chocolates. If the real chocolates don't look so pretty add some real chocolate sprinkles to them!
Now serve it up and observe with delight!
Thanks for taking the time to read. I would love to hear your feed back and if you tricked someone, LET ME KNOW HOW IT WENT! haha.
First Prize in the
April Fool's Contest
Full Spectrum Laser Contest
Halloween Props Contest
Papercraft Contest
