Introduction: Daniel's Positioner Case/Holder Fusion 360
This is a holder for the Daniels Bayonet positioners used on the Daniels AFM8 M22520/2-01 crimper.
This started out as a remix of my “Ignition Wrench Case” Ignition Wrench Case - Fusion360
https://www.instructables.com/id/Ignition-Wrench-Ca...
(also on Thingiverse.com) it has evolved into something more.
I completed the remix of the ignition wrench case by enlarging it and adding the insert for the positioner. Oh, I like parametric programs! In this time, I learned how to 'edit' my files and make them more robust - easier to remix for different uses.
While this came out great in Fusion 360 I never printed it. It is added here in case you want to print it.
I then redesigned a holder it to fit into a case I got from one of my favorite stores (thrift shops) made for Circuit City ‘cityadvantage protection plan’. This has a small 3 ring binder inside that I thought I could use to secure the holder.
The positioners are inserted in the holder with a 1/4 turn to secure it in place.
Step 1:
Using the cut-out for the positioners from the ‘insert for the case’, I copied it over to the newly designed binder holder.
Step 2: Files
Here are the Fusion 360 design files and the .stl's for printing.
Step 3: Slight Problem and Moving On
Problems: I wanted to add text like on the insert case, but there seems to be a known programming problem with Fusion 360 that the designers are working on, which sometimes causes the text to appear inverted. While searching for a solution, and finding a ‘work-around’, I decided to just print it without text allowing me to change what positioners I have in the holder. Hopefully Fusion 360 will repair this soon as on my other projects with Fusion 360, adding text has been a breeze and enjoyably easy.
While this is the first 'problem' I have encounter in Fusion 360, it is still far better than all the inserting text, locking up and more problems I was having with FreeCad. As with all programs you have to find the best way to do the things you want to do.
I am new to Fusion 360 with just a about a month working knowledge and I am still learning more efficient ways to do things. I have not even come close to finding the limit of what can be done - or how quickly! I still highly recommend this program. Check out what this newbie can do with Fusion 360 - (in less than a month) and some thoughts on first using Fusion 360;
https://www.instructables.com/id/Rivet-Drilling-Gui...
https://www.instructables.com/id/3D-Printed-Marble-...
If you print these, please let me know as I always enjoy it when someone can use my designs. Oh, and please vote for me in the contests I have entered!
Remix Contest 2016
Epilog Contest 8
Design Now: 3D Design Contest 2016
