Introduction: Instructables Labs' Vacuum Former (STEP VERSION)
Greeting Instructabrarians!
So here at Instructables Labs we have several truly impressive machines. We have several Epilog laser cutters which can cut through most plastic and wood material and etch almost any shape (Including cylindrical objects!). And we also have a couple of truly astounding, expensive, 3D Printers with an extremely high DPI resolution and can create a real copy of any digital computer model.
BUT, as strange as this may sound, for me these two just weren't enough. Sure the Laser Cutter is impressive at raster etching and vector cutting but its limited by the flatness of its material. And the 3D printer, while awesome, does tend to rack up in the price range as well as take up to several hours to finish. For my interest in rapid prototyping I wanted something fast, accurate and able to create near perfect molds within seconds.
That's why, after nearly a month of development, I successfully created Instructables Lab's first Vacuum Former, Office Edition.
Editor's Note: I'm reposting this as a STEP BY STEP after getting so many requests.
Step 1: About Vacuum Forming
ABOUT VACUUM FORMING
For those of you who don't know what vacuum forming is, there's a really nice description on Howstuffworks.com The phsyics is really simple: take a piece of sheet plastic, stretch it across a rectangular frame, and heat it up to a boiling degree. Then, using either a perforated board or a single sheet with a hole connected to a high suction vacuum, a desired object is placed on top. When the plastic is heated to a malleable degree, the plastic is placed on top of the perf board/ board with vacuum. Vacuum turns on, plastic forms around the object, and instant mold!
Step 2: Parts and Materials
MATERIALS
To build Instructables' NEW vacuum former, all you need are these common household objects
- Tin Tray
- Shop-Vac Vacuum Cleaner (the more industrial strength, the better)
- Strong wooden, rectangular frame
- Large oven
- Cardboard Box
- Painter's Tape
- PVC Pipe connector (or some kind of connector piece that attaches to vacuum nozzle)
Step 3: HOW TO VACUUM FORM EASILY Step 1:
Vacuum Forming is NOT difficult. The only thing that takes a while to understand is knowing how long to leave the plastic in the oven for and what temperature to set it at.
Take a thin piece of sheet plastic. Anything larger than 1/2'' is too large and will not be malleable enough to mold using a domestic shop vac. For best uses, I suggest polystyrene sheet (from Tap Plastics) 1/8'' or any thin flexible clear plastic sheet.
Step 4: Step 2: Attach Plastic to Frame
Choose the appropriate Wooden Frame that your object can fit easily into, while still providing enough space for vacuum suction. I ended up creating three different kinds: a modest 4'' by 6'' photo frame, a larger 7.5'' by 9'' frame, and a very large 10'' by 12'' rectangular frame.
Cut an appropriate sheet from your sheet plastic so it fits over the frame. Then using the blue painter's tape, tape down the edges of the sheet to the frame. You might also want to staple the frame to the plastic, for extremely large objects.
Step 5: STEP 4: Attach Object to Tray
Using a bit of painter's tape, take your desired object and then tape it to the top of the hole on your tray. Make sure there is enough of a gap to provide suction.
Step 6: STEP 5: Preheat Oven
Preheat the oven to 500 Degrees. Nothing less.
Step 7: STEP 6: Most Important Step
Most Important Step: Once you have the oven set to a boiling degree, put in your wooden frame with sheet plastic facing up. Depending on the type of plastic, you may want to lower/rise the temperature at this point. The plastic should already start to deform. Make sure that the plastic on the frame does not touch the bottom of the oven. This entire process happens literally in seconds.
EDITOR's NOTE: I know I'm using an iPhone instead of the head in this step. That's because I ended up posting this photo afterwards.
Step 8: STEP 7: Remove Plastic From Frame
Very quickly take out the frame, lay the plastic face down on top of your object. Turn on vacuum cleaner and then create mold!
Optional Step: If plastic has not formed nicely around your object, use a Heat Gun and melt the plastic a bit more so it deform to a more accurate shape. Turn on vacuum.
Once plastic has dried, carefully remove plastic from object.
Step 9: Conclusion
And that's it! Vacuum forming is literally the easiest process in the world, once you master the technique.
Vacuum forming is a process I have been interested in a very long time. The appeal of creating an exact instant mold without having to spend several dollars on expensive casting or resin, was something I was very dedicated to pursue.
Even though I have a bunch of projects lined up using the new vacuum former, I really built this with the hope that the entire instructables team might find a use for it. DIY Snowglobes, Instant Robot Heads, Waterproof Enclosures, the possibilities are endless!
Well, hope this helped. Go make some cheap plastic crap!
SHIFT!
PS Tap apparently sells both recycled and BPA safe plastic. Or so I've been told.
Green Tech Contest
Hurricane Lasers Contest
