Introduction: Diy Finger Crotchet
About: Photographer | Blogger | Book Lover | Vintage Enthusiast | Instagram: @momo.davis Pinterest: @momodaviss
This tutorial will show you how to make great things from your fingertips!
Step 1: Slip Knot
Make a slip knot, (look it up if you don't know how to do it)
Step 2: Cast On
To cast on, you need to put your fingers through the slip knot, and then grab the working yarn and pull it through
Step 3: Keep Going
Keep doing that until you have your desired length, when you do, add two extra
Step 4: Then Skip
Then skip the two extra rows you made and stick your finger in the loop hole.
Step 5: Pull and Catch
Pull the working yarn over your finger. Then catch it and pull it through
Step 6: Close It Up
Then stick your thumb through and pinch the working yarn and pull it through.
Step 7: Keep on Keeping On
Keep doing this until you each the end!
Step 8: Cast Off
To cast off just simply go to the end on a row, and then cut the string and put it through the hole and pull it tight
Step 9: Finish
To finish, just sew it how you want it to. ENJOY!!!!!!! Vote and thanks for reading
