Introduction: Foam Wall Decore and Frames
I love making things and gifting them...else what am i to do with so many things around the house! :-)
Here is some thing you can gift for a newborn or any child for that matter.
Step 1: Materials
Styrofoam
1" wide 1/4" thick wooden slats
glue
wall filler
acrylic paint
ribbon or anything that can be used to hang
Hot wire cutter
Hard foam boad
Step 2: The Name
Trace the name of the child on Styrofoam. Cut it with a hot wire cutter. Use wall filler to cover the gaps in the styrofoam and leave to dry.
Sand it and then paint it the color you desire.
Step 3: The Frames
Cut 2 circles with a diameter of 3.6"
cut an inner circle or flower with the diameter being 2.6" ( or less if you want a thicker border)
Cut a rectangle 4.5"x 3" and cut an inner rectangle 2" x 3.3"
You can go with any size you want....these are the measurements i got after i randomly drew the shapes.
As the foam i had was water proof , the paint was not sticking to it ..so .i painted it with wall filler...or in America you would call it gesso.
You can give the frame texture by putting on a thick layer and lifting it with your finger...or dragging it. play around!
Let it dry and paint it ....color coordinating with the colors of the letters.
Step 4: The Frame
Line up the name and under it place the frames. Measure the maximum length.
cut 2 Slats the same length.
Glue 3 ribbons...(in one slat)1 in the center.....the other 2 on either side...remember to keep the frames and see if the spacing is right.
now glue the other slat..sandwiching the ribbon between them.
The slats should be in a L shape now ( see picture )
Once dry ...paint and let it dry again.
Step 5: Finishing!
Now glue the name and glue the frame at the end of the ribbons.
Wallah! you now have a personalized gift!
New mom's will love you for this!
BTW...if you don't have a hot wire cutter here is how to make your own!
https://www.instructables.com/id/Table-top-hotwire-Styrofoam-cutter/
Holiday Gifts Challenge
ShopBot Challenge
