Introduction: How to Make a Dresser (with Crates for Drawers)
This is a step by step build of a nice little dresser that uses crates for drawers.
Be sure to check out the video if you get lost along the way:
1x12 or 12” edge glued lumber 6 ft 1 pc
1/4” utility panel 4x8 sheet 1pc
1/2” plywood 4x8 sheet 1pc
12” edge glued lumber at 8ft 1pc
1x2’s 8ft 5pcs
1x3’s 8ft 1pc
18” drawer slides 4 sets
1 1/4” pocket holes 100pcs
Paint, glue, stain and polycrylic as needed
Crate materials (also some of the 1/2' plywood above)
2x6” 8ft 1pc (makes about 8 crates)
1x8” 10ft 1pc
Step 1: Cut Up Some 1x2s
Cut 6 pieces at 45.5”
Cut 2 pieces at 17”
Cut 4 pieces at 13”
We will be using these to make the face and frame of our dresser
Step 2: Cut Up a 1x3
Cut 2 pieces at 17”
Cut one piece at 13”
We will be using these for the face and frame on the bottom of the dresser
Step 3: Put Some Pocket Holes in Those Boards
Put 2 pocket holes on each side of those boards you just cut out (except the 45.5” 1x2s).
Step 4: Assemble the Face
Put a 45.5” 1x2 on each side.
Then mount a 13” 1x2 to the top using pocket screws and wood glue.
Attach a 13” 1x3 to the bottom.
Then attach the last three 13” 1x2s evenly spaced between them. There should be a 9 1/4” gap between each board.
Step 5: Assemble the Two Sides
Use a 45.5” 1x2 on each side
then attach a 17” 1x2 on the top and a 17” 1x3 on the bottom.
Step 6: Sand These Pieces Down
Step 7: Start Assembling
Attach the face to the front of the two sides using finishing nails or a brad nailer and wood glue. We want the sides of the front boards to be flush with the left and right sided
Step 8: Cut Up Some 1/2” Plywood
We need two pieces that are 19.5” x 43.5”
And one piece that is 19.5” x 14.5”
Step 9: Cut Four 6” Strips of 1/4” Utility Panel
Then cut those into 14 pieces that are 19.5” long
Step 10: Attach These Pieces to the Two Large Pieces of Plywood
I used wood glue and some super short brad nails to attach these. They have a 1/4” gap between them
Step 11: Attach the Two Sides and the Bottom
Use wood glue and finishing nails to attach the sides to the inside of the dresser. Make sure the two sides are flush with the top.
Then attach the bottom using glue and finishing nails
Step 12: Cut a Pieces of 1/2” Plywood to 14.5”x45.5”
This will be for the back of our dresser
Step 13: Attach the Back Using Wood Glue and Finishing Nails
Step 14: Cut 2 Pieces of 12” Edge Glued Lumber at 17” Long
Rip one piece down to 9 1/4” wide using the table saw.
If you are using 1x12s instead of edge glued lumber rip the one piece down to 10” wide
Step 15: Assemble Those Two Pieces With Wood Glue and Pocket Screws
Step 16: Attach the Top
Use wood glue and pocket screws to attach the top.
The front and sides should overhang 1/2”
Step 17: Install Some 18” Drawer Slides
I used a square to make a mark that was perpendicular to my openings. I also attached my drawer slides close to the top to the drawers looked like they were hanging
Step 18: Build 4 Crates
Check out my instructable on how to build these:
https://www.instructables.com/How-to-Make-a-Better-Crate/
Step 19: Mount the Drawer Slides Onto the Crates
I attached the first crate with the dresser on its side to see where they should be mounted so there would be a 1/4” gap on the top and bottom of the crates.
Then I attached the rest of them outside of the dresser
Step 20: Install Your Drawers
Step 21: Fill Your Nail Holes and Sand
Step 22: Paint and Stain the Way You Want
I used Provincial stain for the top from minwax
A polycrylic for a clear coat
And an oil based white paint on the sides from rustoleum
