Introduction: How to Use TILT Sensor With LED, BUZZER and ARDUINO
The tilt sensor is a component that can detect the tilting of an object. However it is only the equivalent to a pushbutton activated through a different physical mechanism. This type of sensor is the environmental-friendly version of a mercury-switch. It contains a metallic ball inside that will commute the two pins of the device from on to off and viceversa if the sensor reaches a certain angle.
Step 1: Video Tutorial
Required Hardware:
LM393 Tilt Angle Sensor - https://bit.ly/3m3FgGX
Arduino Nano V3 - http://bit.ly/2RTa3rp
LED Kit - http://bit.ly/37OajhS
5V Buzzer - http://bit.ly/33koZn5
Breadboard - http://bit.ly/30ckFoc
Jumper Wires - http://bit.ly/2MtyZCX
Step 2: Circuit
TILT Sensor to Digital 2
LED to Digital 4
BUZZER to Digital 3
Step 3: Get the Code
GitHub: https://github.com/MertArduino/How-to-use-TILT-sensor-with-LED-BUZZER-and-ARDUINO
#define TILT 2#define LED 4#define BUZZER 3void setup() { Serial.begin(9600); pinMode(TILT, INPUT); pinMode(LED, OUTPUT); pinMode(BUZZER, OUTPUT);}void loop() { int TILT_VALUE = digitalRead(TILT); if (TILT_VALUE == LOW){ digitalWrite(LED,HIGH); digitalWrite(BUZZER, HIGH); delay(1000); } else { digitalWrite(LED,LOW); digitalWrite(BUZZER, LOW); }}
