Introduction: Knex Cablecar V2
Well, as a few requested, I have made another cablecar, similar to my other one, except this one runs on string. The only other major differences are that it is smaller and is geared to run faster.
Video for the original and v2 will be coming up soon.
Enjoy!
Step 1: Piece List
Okay. Here's the part list.
Rods:
Yellow - 4
Blue - 4
White - 12
Green - 22
Connectors:
Light grey (2 slotted) - 4
Red - 8
Yellow - 8
Purple 3d - 8
Random bits and pieces:
Tiny blue gears - 2
Red Gears - 2
Small grey wheels - 3 (without tires)
Tan Clips - 14
Silver spacer - 8
Blue spacer - 14
Other:
1 power pack, motor pack, power motor or whatever its called... Preforably one with a short cord, I had to use one with a long cord however.
Scissors or hands of steel to cut the string
And lastly string. Enough to go from where you want your cablecar to go between.
Alright, lets get this party started!
Step 2: Axles
There are 3 axles on the cablecar. The front and back ones are the same. Go!
1: Build it. The tan clips/spacers are the same on the other side
2: Another view
3: Build another identical one
4: Make this axle
5: Another view. There is a #32 elastic doubled up around that wheel as you can see. This may or may not be necessary for grip depending on whether your cablecar will be going uphill at any point. I suggest adding it regardless.
Step 3: Side Panels
Super easy step. Rock it.
1: Yeah... Those are the side panels. Remember the blue rods.
Step 4: Motor Assembley
Build the one piece in all the photos. Sorry I didn't take it apart, but you'll be fine. You can wrap up any extra cord as I did, though it may be easier to do once it is all assembled.
Step 5: Putting It Together
Really easy. Snap snap!
1: Put the two side panels togther like so
2: Add that motor assembley to the bottom like so
3: Just showing you how I dealt with that extra motor cord
4: Add the axle with the gears on it as shown
5: Pop the other two in the two ends
Yay!
Step 6: Set It Up!
Yes, it is time to set it up. Grab your string and some scissors. Basically, tie a piece of string between two objects. I suggest tying one end in a bowline and then slipping that over a nail or something similar so you can just pop it off and on when you want to put the cablecar on it (photo one). The string goes under the wheels at the front and back, under the blue rods and over the middle wheel (photo two). You'll want to make the string as tight as possible without it breaking so as to make it not sag.
Good luck!
Step 7: Done!
You're done!
Thanks so much for viewing my instructable! As an extra little bonus (with emphasis on the little...) here's a photo of a super small cablecar I made, it was dreadfully jerky and unstable, so I didn't add it to the instructions, but I'm sure you could make if from the single photo. Anyways...
Thanks again!
-IaC
