Introduction: Memom's Apple Pie With Simple DIY Crust
This is the old fashioned apple pie recipe our grandmother, who we call Memom, has been using for centuries (don't tell her I said that). It is simple and the flaky crust is easy enough that even my ridiculous niece can make it. Revel in the astonishment of all your guests when they realize you made the crust yourself!
Step 1: Ingredients
Ingredients
Ingredients below. I'll repeat them in the follow-up steps.Apple filling
- 7-8 apples
- 2 tbl flour
- 1 cup sugar
- 1 tsp cinnamon
Crust *
- 2 cups flour
- dash of salt
- 1/2 cup oil -- any vegetable oil will do, including olive oil.
- 1/4 cup milk
Cook at 400 degrees for 50 minutes
Utensils/implements
You'll need the normal bowls, measuring spoons/cups, etc. The important item, which makes rolling out the crust so much easier, is wax paper.What kind of apples?
Use tart apples with firm flesh. MacIntosh and Cortlands work best; Granny Smith can also be used. Don't use anything with "Delicious" in their name--they're useless for pies.Step 2: Peel and Slice the Apples
- Remind you to peel the apples first.
- Prove that my niece really can help around the house (it doesn't happen often!)
Step 3: Mix the Cinnamon and Sugar Pie Filling
- 2 tbl flour
- 1 cup sugar
- 1 tsp cinnamon
Step 4: Make Up the Crust Dough
Crust: *
- 2 cups flour
- dash of salt
- 1/4 cup milk
* - We often increase the ingredients for the crust by 50%. This results in a thicker crust that is easier to roll out.
Step 5: Roll Out the Bottom Crust and Place It in the Pie Plate
Take the larger ball, lay it on a piece of wax paper, and flatten it into a thick disk with more dough near the edges. Place more wax paper on top and roll out the crust until it's larger than the pie plate. Did I mention you want to roll it as little as possible?
Peel off the wax paper on one side, drop it into the plate, then peel off the other. Viola!
Step 6: Fill the Pie With the Apples and Sugar/cinnamon
Fill the pie plate with as many apples as you want, then pour the cinnamon sugar evenly around the top.
Step 7: Roll Out the Top Crust and Place It on Top
Roll out the top crust between the wax paper like before. Don't roll it too much! Once the crust is placed on top of the pie use a fork to crimp the edges tight, then make a few slits on the top with a knife. This lets some of the moisture from the apples escape while the pie cooks.
Step 8: Cook and Eat!
Place in the oven at 400 degrees and cook for 50 minutes. This will usually result in a pie with whole apple slices. If you want the apples to break down more, cook longer with a piece of tin foil on the top of the pie to prevent it from burning. I usually place a cookie sheet under the pie to catch dripping apple juice.
Let it cool and then eat. Cinnamon ice cream pairs very well with this pie but it can easily stand on it's own. Enjoy!
Baking Contest
