Introduction: Metal Yard Art(YART)!!!
This is just a little fun project I decided to make with some scrap stuff around the shop.
Step 1: Tools and Materials
tools
bandsaw
arc welder I set the heat in the low 40's and used 3 welding rods
1/8 720 welding rod SS
Materials
cable eyes(10)
3/4*1 1/2 bolt
3/4 washer (2)
Step 2: Putting the Pieces Together
I cut the big pipe strap and decided not to straighten it.
Welded everything from the backside to keep it clean looking. started all of the cable eyes with a small bead into a small flower looking circle.
Step 3: Stuck
Put my bolt on the table and set my circle on top. Again welded from the backside, securing them. Welded the stem to said bolt.
Step 4: Leaves
Tacked on these. It looked like it needed a little more.
Step 5: Heat Color
At first I thought about sand blasting, then a passerby said throw the rosebud and see what it looks like. And after doing that decided that it looked great. After it cooled I knocked the dust off and was quite happy with it. It took about 30 minutes and if you had to buy the parts it could be bought for maybe $20 and even less if you use carbon steel.
Step 6: Finite
I will probably move it later but for now it is done.
Outdoor Workshop Contest
Metal Contest
Epilog Challenge VI
