Introduction: Recode Rethink Resign Jewelry
A collection of classic, generative artworks that were recoded, reimagined and made into jewelry. They are high quality art-pieces molded into sythetical resign. Follow these instructions to make your own artistic resin jewelry.
Materials:
  • Photopaper 150g
  • Printer
  • Scissors
  • Computer
  • Gloves
  • Epoxy resin
  • Hardener
  • Silicone mold
  • Mixing cups
  • Stirring sticks
  • Drill
  • Eye screws or jump rings
  • Chains or cords
Step 1: Prepare Your Work Area
Make sure you have a clean and well-ventilated area to work in. Cover your workspace with a plastic sheet or newspaper to protect it from spills.
Step 2: Generate Tiny Artworks
Generate various patterns with the help of the opensource software "Processing". Get inspired by classical artworks such as by Piet Mondrian, Wassily Kandinsky or Jackson Pollock. Export the results to a JPG and save them on your computer.
Step 3: Print on Photo-paper
Now print the artworks with a photo-printer. Make sure they are in the same shape and size of your silicone-molds. Then cut the printed shapes out with some sissors.
Step 4: Mix the Resin and Hardener
Put on your gloves. Mix the epoxy resin and hardener according to the instructions on the package. Stir the mixture thoroughly for at least five minutes to ensure it's well-blended.
Step 5: Pour the Resin Into Molds
Pour the resin mixture into silicone molds. Fill them to the middle.
Step 6: Add Pieces of Paper
Add your pieces of artworks printed on photo-paper to the resin mixture. Press the paper down until it almost reaches the ground. Make sure your resign remains in the mold.
Step 7: Let It Cure
Allow the resin to cure for at least 24 hours. Keep it in a warm, dry place and avoid touching or moving the mold during this time.
Step 8: Remove From Molds
Once the resin has cured, carefully remove the jewelry pieces from the molds. Use sandpaper to smooth any rough edges.
Step 9: Add Eye Screws or Jump Rings
Drill a small hole in the top of the resin piece and insert an eye screw or jump ring. This will allow you to attach a chain or cord to your jewelry.
Step 10: Add Chains or Cords
Attach your chains or cords to the eye screws or jump rings.
Step 11: Wear Your Jewelry
Your Recode Rethink Resign Jewelry is now ready to wear. Enjoy your new unique art pieces!
Jewelry Contest
Jewelry Contest
