Introduction: Upcycled NOW Watch--Picture Frame on Your Wrist!
A friend of mine saw this "always exactly accurate" watch online for $50 and asked me "do you think we could make this out of an old watch?"
This classy upcycled watch will inspire you to seize the day and fight any procrastinating spirit. "When should I ask that cute girl out on a date?" NOW. "I really should study for my test, but..." DO IT NOW. "If only I could quit my boring job and follow my dream of starting a successful online travel program that shows viewers how to visit exotic locations on the cheap" (this is what my friend who wanted the watch actually did. You can see his show at www.TheHostelLife.com).
Stop procrastinating; NOW is the time!
Even if you are not interested in making your wrist say "NOW," this instructable will show you how to turn your old, broken watches into wearable wrist picture frames.
Step 1: Tools and Materials
TOOLS:
- precision flathead screwdriver
- pliers
- exacto knife
MATERIALS:
- broken or thrifted watch. This very manly leather-banded style is easy to find and great for guys!
- black foamcore
- "NOW" design (or whatever other graphic you want to put inside the watch). I've uploaded a page of "NOW"s in different sizes for you to print off and find the best fit for your watch.
- rubber cement
Step 2: Gut It!
Examine the back of your watch to see how to remove the backplate. Some have tiny screws, some you need to pry open. I have the pry open kind. After trying to get the back off for an hour, I realized that this watch was jammed shut far beyond my opening abilities. I took it to WalMart's jewelry section and the employee there opened it up for no charge.
Once you get the back off, carefully pull out the watch pins on the side and lift the whole time mechanism out of the watch body. Set aside for later disassembling.
My watch had a plastic band on the inside marking the 12, 3, 6, and 9 spots. I grabbed it with pliers, bent it back and forth a bit to loosen it up, and yanked it right out.
Now you have a beautiful, wearable picture frame ready to be filled!
Step 3: Cut Foamcore to Fit
Cut a piece of foamcore down to snugly fit inside the back of the watch. Don't worry about cutting perfect rounded corners- just cut a rectangle and notch off the corners until the foamcore fits right in.
Step 4: Glue on Your Design and Wear Your Watch!
Print out your design. If you are using my "NOW" sheet, put the paper on a table, move the glass watch frame on top of each "NOW" until you find the size you like. Cut out the best sized "NOW", leaving a generous amount of black space around it.
Brush rubber cement on one side of the foamcore and center the "NOW" on it. The easiest way to center the word on the foamcore is to hold the paper and foam up to a light, move the paper around until the word is in the right spot, and let the glue dry.
After drying, turn the paper and foamcore upside-down and cut the excess paper off with an exacto knife.
Fit the foamcore into the glass watch frame and put the backplate on. You may have to trim a bit of the height off the foamcore to get the backplate to lock back into place.
Wear your watch and get motivated!
Now that you have your watch gutted and the backplate loosened, it is easy to make interchangeable images on foamcore for the inside. You could change out the word or picture daily to match your mood or style and use your new, upcycled watch as a custom wearable picture frame!
Runner Up in the
Pocket-Sized Contest
4th Epilog Challenge
Hack It! Challenge
