Introduction: "Ur Choice"
The idea of paint shopping just sends chills down my spine. In order to get rid of the hassle of paint shopping i came up with a device that reads and displays the RGB value of the color scanned. That way color shopping is no longer looking at paint sample cards but instead looking at the color actually being used.
This instructable will teach you how to make and use "Ur Choice".
"Ur Choice" is a device that detects the RGB value of a particular color and displays it on a LCD Screen. The information given can be used in different life situations such as matching or finding colors for jobs such as painting. The uses of this product are not limited so please don't limit yourselves.
Step 1: Materials
The following materials is what is needed to build "Ur Choice": First you will need a TCS3200-DB Color Sensor, db expander, a switch, and a Parallax 2x16 Serial LCD, 3 pin expander, and a soldering iron a basic stamp Home work Board and a roll 22 gauge wire.
Materials you must order: TCS3200-DB Color Sensor, db expander, Parallax 2x16 Serial LCD
Step 2: LCD
Wire LCD to bread board as shown in the following diagram. make sure to run a wire to the bread board in a separate row.
Step 3: Sensor
Plug the DB expander into the color sensor. Then insert the DB expander on the bread board as followed in the PDF file. Adjust pins as needed while connecting the the ground as the same row as the LCD allowing both devices to run on the same ground.
Step 4: Switch
Take the two 22 gauge wires and solder one wire on the peg that says power and take the other wire and solder that wire on the peg that says ACC. Connect ACC into vss and take the wire that says power and insert it in the same row as the LCD and Sensor connecting the circuit with the switch.
Step 5: Code
Type in the following code shown below.
' {$STAMP BS2}
' {$PBASIC 2.5}
TX PIN 0
#SELECT $STAMP
#CASE BS2
T19K2 CON 32
#ENDSELECT
LcdBkSpc CON $08 ' move cursor left
LcdRt CON $09 ' move cursor right
LcdLF CON $0A ' move cursor down 1 line
LcdCls CON $0C ' clear LCD (use PAUSE 5 after)
LcdCR CON $0D ' move pos 0 of next line
LcdBLon CON $11 ' backlight on
LcdBLoff CON $12 ' backlight off
LcdOff CON $15 ' LCD off
LcdOn1 CON $16 ' LCD on; cursor off, blink off
LcdOn2 CON $17 ' LCD on; cursor off, blink on
LcdOn3 CON $18 ' LCD on; cursor on, blindfgdfk off
LcdOn4 CON $19 ' LCD on; cursor on, blink on
LcdLine1 CON $80 ' move to line 1, column 0
LcdLine2 CON $94 ' move to line 2, column 0
charIn VAR Byte ' input from user
baud VAR Word ' baud rate for Serial LCD
S0 PIN 3 ' A
S1 PIN 15 ' B
OUT PIN 6 ' C
LED PIN 4 ' D
S2 PIN 8 ' E
S3 PIN 5 ' F
' -----[ Constants ]-------------------------------------------------------
' Define count periods for each color. Adjust these for readings just under
' 255 for a white sheet of paper.
pRED CON 13 'Red reading period.
pGREEN CON 12 'Green reading period.
pBLUE CON 11 'Blue reading period.
' -----[ Variables ]-------------------------------------------------------
RED VAR Word 'Red color reading.
GREEN VAR Word 'Green color reading.
BLUE VAR Word 'Blue color reading.
HIGH S0 'Maximum output rate.
HIGH S1 ' "
HIGH LED 'Turn on LED.
baud = T19K2
main:
DO
SEROUT TX, baud, [LcdBLon]
PAUSE 500
GOSUB Color 'Get the color data, and output to DEBUG.
DEBUG "R", DEC3 RED
DEBUG " G", DEC3 GREEN
DEBUG " B", DEC3 BLUE
DEBUG CR
SEROUT TX, baud, ["R", DEC3 RED] ' send char/num to LCD
SEROUT TX, baud, [" G", DEC3 Green]
SEROUT TX, baud, [" B", DEC3 Blue]
PAUSE 500
END
LOOP
END
' -----[ Initialization ]--------------------------------------------------
HIGH S1 ' "
' -----[ Program Code ]----------------------------------------------------
' Color: Read all three color components.
Color:
LOW S2 'Address the red output.
LOW S3
COUNT OUT, pRED, RED 'Read the red component.
HIGH S3 'Address the blue output.
COUNT OUT, pBLUE, BLUE 'Read the blue component.
HIGH S2 'Address the green output.
COUNT OUT, pGREEN, GREEN 'Read the green component.
RETURN
Step 6: Finished Product
The finished product would have a box around the wiring allowing the LCD, the sensor, and the switch able to use. due to time and limited resources we were only able to have our finished product. Don't let this stop you. Building a box ca be easy just make sure you take measurements in order to have the product fit in the box. Make cut outs in order for the parts to have exposure and you have a pretty Ur Choice.
