Introduction: WATERPROOF Rainbow Origami Vase
I have loved origami since I was a little girl, I enjoy spending my free time folding papers and I really enjoyed creating this Vase, I hope you will like it and spend hours of fun making it as I did.
It is waterproof so you will be able to use real flowers with it.
For making this WATERPROOF Rainbow Origami Vase you will need:
238 (7 x 3,5 cm) RED papers
616 (7 x 3,5 cm) ORANGE papers
546 (7 x 3,5 cm) YELLOW papers
567 (7 x 3,5 cm) GREEN papers
602 (7 x 3,5 cm) BLUE papers
245 (7 x 3,5 cm) INDIGO papers
175 (7 x 3,5 cm) VIOLET papers
Pre-catalyzed polyester resin
Catalyst
Step 1: Creating the Pattern
For creating the pattern I would follow in the Vase, I started drawing on papers what I imagined and then selected the one I liked the most. I studied the pattern on illustrator and then draw how should I join the papers for getting the pattern I wanted (you can find how to join the papers on the attached PDF y repeated the pattern 7 times to the right and ended where I started, creating that way a circle and then the vase.)
Step 2: Folding the Papers
You need now to fold each paper as shown in the picture.
(Take your time and be patient.... It will take a while to fold 2989 papers)
Step 3: FOLD 2989 PAPERS!
Step 4: Assembling the Modules
The module used in this Vase is very common in origami, so learning it and how to assemble them will let you create thousands of figures, you can start following instructions as the one I made here, but then you can also create your own figures.
To assemble them you will put the leg of one into the pocket of another, make sure to keep them alternating so that each new module you put on is resting on two different modules. This modules are like the LEGO of origami.
On the attached pictures you will find the process of making the Vase. If it becomes too difficult to keep the shape you can add some glue to keep the pieces assembled.
Step 5: Resin
Now it is time to cover it with resin so it will be waterproof.
What I did was to mix the resin with its catalyst (as the instructions said) and cover the Vase with it, starting from the inside and to be sure I covered it all, I repeated the process 2 more times. (Remember to do it outside)
Then, let it dry for 24 hours.
Step 6: Proving It
I added water to the top to see if it was working and let it some time like that, it worked perfectly.
Now it is time to add some beautiful flowers.
Step 7: In Context
First Prize in the
Colors of the Rainbow Contest
