Introduction: Window Greenhouse
'The Window Greenhouse' is how I've approached the challenge of getting more sunlight for my starts. A method of creating a greenhouse great for anyone looking for a simple way to extend the season or grow with limited space ---or for renters like us who want a real greenhouse!
Approach. The instructable uses materials around the house. A single plastic bin makes a wonderful greenhouse provided it is clear and has a solid edge that fits in your window... next year i will likely add a second bin to effectively create a 'double-pane' greenhouse... more tips later
Insulation & Infiltration. In this instructable I'll walk through how to effectively create a barrier between your home and the outdoors while installing a window box.
Anyone can do this... I really think this is the easiest way for anyone to get started with a window garden. Perfect for a single family home or urban apartment provided you have a south facing single or double-hung window. ---be careful for people below if you are in an apartment!
----using sketchup? get started with the attached file
Step 1: Test Fit - Complete
Going from the initial test-fit of the plastic bin is a series of steps that involved cutting foam to fit the opening.
Simple Method - the simplest approach would be to cut two rectangles that fit around the bin... there really isn't much to this process. If you are inclined to apply a heavy bead of caulking you can probably get a finished product in only two steps.
Insulated Method - adding a couple extra steps means you'll have a better insulation and air gab. This is a good thing for comfort in the house and for the young seedlings that often prefer a warm environment.
Step 2: Tools & Materials
Most materials are easily found around the house. You may need to buy foam but you can often find scraps around construction sites.
Materials
- Plastic Bins - commonly referred to by their brand names... Sterilite or Rubbermaid. Any bin will work provided it has a solid edge and fits your window. I find a deep bind around two feet is ideal. Even better if you can use two... it effectively creates an extra air layer much like a double pane window. ----you may find them better priced in the walmart plastic bin aisle
- Rigid Insulation - a building product that shows up on most building sites here in MN. A really wonderful product for crafts. The material comes in a standard 2" depth. Any of the colors (yellow, pink, blue) work fine for this project. Always available new at a big box.
- Duct Tape - happy to share a use for this product that actually fits its name! Duct tape is sold to seal air gaps and that's exactly what it can do for you on this project. If you're on this site you likely own a roll (or several)... you can always get lost searching here on amazon.
- Sealant - not show in the instructable... like many of my garden projects they are planned as tests and will be modified each year. I see it as worth adding a bead of sealant to cut down on air infiltration between the foam and plastic bin. ---here's a link to a waterproof sealant I found on amazon. I think they are selling small tubes now at dollartree.
Tools
- Olfa Cutting Tool - yes, this really is my favorite. It's something I use on most craft/building projects. Here it is particularly useful to extend the blade. The Japanese steel really holds up to the rigid insulation that has tough fibers... it will quickly wear down a kitchen knife. ---impressed. the Olfa L1 price actually came down to $6.95. It's always hovered around $10.
- Cutting Mat - always hand and a good way to protect your worksurface. I'm simply using a 1'x1' mat so that if my blade runs past my material I land on a solid surface. ---there are a lot of options.
- Sharpie - easiest way to write on foam. also useful to make a notch with you blade.
- no ruler method - you may find it strange but it's pretty straight forward to work this project without a ruler... I find it convenient to mark on the foam. A couple scrap pieces of foam are also useful to transfer dimensions.
Drawing File - Please see the drawing file is available for download. You may find it useful to scale the window or look at the layout in a 3D drafting program.
Step 3: Header & Sill
---note that in this diagram UP is to the LEFT.
Width -at this point you're looking for the width of the window plus 2". This should give you a workable width and 1" extra at each end.
Depth - the foam I recommend comes as a standard 2".
Height - more detail below on how to create the header and sill.
Header & Sill
See the images for how I notch the header and the sill. The idea here was to be roughly centered in the foam but to allow for a thicker layer on the inside of the window. There are two reasons to keep the inside edge thicker...
- Insulation - A thicker surface allows for more insulation and greater contact along the edge of the plastic bin.
- Support - The weight of the bin should sit on the window sill and pull against the header... that said, a thicker lip of insulation will also catch a portion of the load and it's useful to have a little over 1" of material.
Sill Channel - wherever possible a channel is better than an angle. The channel makes for a tight fit that really cuts down on air infiltration. In the next step I'll show how to cut the channel.
Step 4: Cutting Technique - Sill Channel
Cutting foam is very simple. The main caution is to not feel too confident. The knife can move quickly and that's how most people cut themselves. Make deliberate cuts.
- Score - you want to run a first pass along the surface. Easy to use a straightedge or use a finger along the edge to guide your blade. For this step you may want to keep your blade short
- Deepen the Cut - once you have an initial path for the blade make another couple passes to get the desired depth. For this sort of 'rabbet' cut (to borrow from carpentry) you want to first cut at 90 degrees.
- V-Cut - after cutting straight down on the edge you'll come at an angle to cut material. I often work with an extended blade but this isn't necessary.
- Loosen Material - from there you can use the edge of the knife or even a screwdriver to remove the loose material.
- Compaction - when insulation is packed down it loses it's insulating ability. That said, it works well in our case because it helps create a tight seal. The main challenge in our case is air infiltration around the perimeter.
Step 5: Cut the Width
See that in the diagram there are three sections that add up to the width of the window. The exact width of any single piece doesn't matter as much as them all adding up to the width.
- A - Left Foam
- B - Plastic Bin
- C - Right Foam
My preference is to have the bin located closer to one side or the other. I suggest starting with the long side... if you have problems cutting the edge to match the bin you can always make it the short side.
Extra Length - remember to allow an extra 1" on each side. This will give you a lip the same way you have a lip against the window in Step 3.
Step 6: Scribed Edge - Fit to Bin
Yes, it's helpful to keep your side pieces long. The process of fitting, or scribing, the edge is straight forward but if it's your first time you may want a test cut. (some tools, like this veritas log scribe, are way too intense)
Scribing - there are a number of carpentry tools to help scribe. It is a common practice when fitting trim along edges or flooring that isn't straight. I find for our case a sharpie is the best tool.
Notching - to complete this cut you'll need to cut in two dimensions. The easiest way is to first take off 1/2" of material and then take off more... you'll likely want to take off a total of 1". Some bins aren't exactly straight on their top lip. You can add an angle if you want bring out your inner sculptor. The easier option is to simply use a piece of duct tape along the joint.
Step 7: Finished Notch
Useful to fit the cut piece in place against the plastic bin and making slight adjustments for your cuts. Think of this part of the cutting more like carving.
This bin has a straight edge and then a curved lip. The notch allows the bin to rest up against the foam very similar to how the header rested in Step 3.
Step 8: Enjoy!!
Thank you for following!
Yes, this project should help start your plant babies and get the garden off to a good start. Here in MN we have a winter that doesn't seem to end. Our last snow fall was only a few days ago.
Hope you find this useful and are a step closer to starting a window garden.
Thanks, Jeff
For more gardening instructables see a few I created from last season:
- First Greenhouse - this lean to greenhouse kept kale alive through this year's arctic blast - awesome!
- Hunting Vine Borers - these bugs are the worst if you grow squash. here's how to take care of them.
- Propagation for Travelers - how I use travel to grow my garden!
Oh, and consider voting below in the Gardening Contest if you've enjoyed this post!!
Runner Up in the
Gardening Contest
