Introduction: 888-846-6939-Convert QuickBooks Mac-Windows Data Files
The process of sending a QuickBooks for Mac data files to an accountant with QuickBooks for Windows is termed as Round tripping. It is also known as round-trip transactions as with it data files return back to the same place from where they are originated. Due to the variation in the type of database that each program use, there is not an Accountant's Copy feature available in QuickBooks for Mac. As a result, round tripping is sometimes a necessary process to make changes to a Mac client's company file. In case you are not able to convert QuickBooks Mac-Windows Data Files, then you can take reliable help from a technical support providing company, like Intelli Atlas. The company QuickBooks technical support staffoffers help to convert QuickBooks Mac data to Windows version and vice-versa in an efficient manner.
Prepare your Macintosh file
· Update your version of QuickBooks for the Mac to the latest release.
· Check for any special characters >Open the file in QuickBooks and delete all memorized transactions >Resort your lists.
· Verify your company file> Run the Custom Transaction Detail Report> Go to Reports > Custom Transaction Detail Report.
· In the Modify Report window> Tap the Dates drop-down arrow and select All.
· Tap OK to run the report > and Check for any memos.
· Edit the transactions and remove the memos. Rebuild the file again.
QuickBooks online tech support provides reliable technical assistance for converting data files between QuickBooks Mac and Windows when you approach Intelli Atlas certified QuickBooks technicians.
Convert your Macintosh file to a Windows file
· First of all, open the company files in QuickBooks for Mac.
· Go to File > Export > To QuickBooks for Windows.
· Select a name and location for the file.
· This backup for Windows can be opened in QuickBooks for Windows.
· Now, rename the company file so that you do not overwrite it when the updated copy is returned.
· Once the backup for Windows is on the Windows machine >open QuickBooks for Windows.
· Go to File > Open or Restore Company.
· Tap Restore a backup copy (.qbb) and then tap Local backup.
· When asked to update the data file to the new version, type yes and then Tap OK.
Convert your Windows file to a Macintosh file
· Simply update your version of QuickBooks for Windows to the latest release.
· Open the company file >Resort your lists.
· Go to File > Utilities > Copy Company File for QuickBooks Mac.
· Save the file.
· Once the file is on the Mac, open QuickBooks for Mac.
· Go to File > Restore > From a Disk.
· Select the copy for Mac, and Tap Open.
· Restore a QuickBooks for Windows file, Tap OK.
· Enter a name for the restored file, and then Tap Save.
For more solutions, visit the official website of QuickBooks and get more reliable technical support for converting QuickBooks Mac-Windows Data Files in an efficient manner.
