Introduction: Altoids Tin Emergency Candle
This is my first instructable and I decided to make an Altoids emergency candle, since I had a tin lying around and have not seen one. This is used if the power goes out or if you need a candle say when camping or if you are traveling. There are five wicks in the candle, matches and strikers within the Altoids tin.
Step 1: Materials
tin can/soup can
candles(mine were a little bigger than tea light candles)
matchbook matches
i used a red crayon for color
hot glue gun
duct tape
Step 2: Preparing the Tin
I cut the top of the matchbook off and cut off the striker parts of the box. I then taped the matchbook into the inside top part of the tin. I used tape because if the matches ran out I could take it off and add another matchbook. Using hot glue I glued the strikers into the tin right next to the matches.
Step 3: Making the Candle
I took the wicks from the candle and hot glued them into the tin.
Then I melted down the candles inside a soup can that was placed in a pot of water.
When it was melted I poured it in around the wicks in the tin.
As the wax was cooling I cut down the wicks to the right size, (about the top of the tin) and took the left over pieces to make more wicks.
I then melted some red crayon wax and mixed it into the candle wax to add some color to it.
To get the wax to cool faster I put it into the freezer for a few minutes.
Step 4:
When the wax was cooled I lit one of the wicks and well it works, now I have an emergency candle any time I need it.
