Introduction: Beebeecraft Tutorial on How to Make a White Pearl Flower Pendant Necklace
Summary: Looking for handmade pearl necklace designs? This article is about a white pearl flower pendant necklace. To know how to make this pearl flower pendant necklace, just keep reading.
Step 1: Supplies Needed in DIY the White Pearl Flower Pendant Necklace:
10mm White Round Pearl Beads
4mm White Round Pearl Beads
6mm Golden Stardust Beads
0.3mm Tiger Tail
11x8mm Pink Faceted Drop Beads
Golden Chain Necklace
Golden Headpins
Stainless-Steel Scissor
Round Nose Plier
Step 2: Make the First Part of the White Pearl Flower Pendant Necklace
1st, cut a piece of 0.3mm tiger tail. Then, thread 4 4mm white round pearl beads to it;
2nd, cross the left tiger tail through the rightmost 4mm white round pearl bead;
3rd, split the two tiger tails apart. Then, thread 3 4mm white round pearl beads to the left tiger tail. Thread 4 4mm white round pearl beads to the right tiger tail;
4th, cross the left tiger tail through the top 4mm white round pearl bead on the right tiger tail;
5th, thread a 4mm white round pearl bead to the two tiger tails respectively. Then, cross the two tiger tails through another 4mm white round pearl bead;
6th, cross the left tiger tail through the left 4mm white round pearl bead. Then, cross the right tiger tail through the right 4mm white round pearl bead(as shown in the picture).
Step 3: Make the Second Part of the White Pearl Flower Pendant Necklace
1st, thread 6 4mm white round pearl beads to the two tiger tails respectively;
2nd, cross the left tiger tail through the left 4mm white round pearl bead. Then, cross the right tiger tail through the right 4mm white round pearl bead (as shown in the picture);
3rd, cross the left tiger tail through the two adjacent white pearl beads. Then, wrap the right tiger tail;4th, thread 8 4mm white round pearl beads to the right tiger tail. Then, make a hoop with the rightmost 4 4mm white round pearl beads by crossing the tiger tail through the
4th 4mm white round pearl bead (as shown in the picture);
5th, thread 3 4mm white round pearl beads to the same tiger tail. Then, cross the tiger tail through the leftmost 4mm white round pearl bead(as shown in the picture).
Step 4: Make the Third Part of the White Pearl Flower Pendant Necklace
1st, thread 2 4mm white round pearl beads to the left tiger tail. Then, cross the right tiger tail through the bottom 4mm white round pearl bead and tighten;
2nd, thread 6 4mm white round pearl beads to the right tiger tail. Then, cross the tiger tail through the 4mm white round pearl bead (as shown in the third picture);
3rd, cross the tiger tail through the adjacent 2 4mm white round pearl beads. Then, thread 4 4mm white round pearl beads to the same tiger tail;
4th, cross the tiger tail through the adjacent 2 4mm white round pearl beads of the other pearl leaf pattern (as shown in the picture);
5th, cross the tiger tail through the adjacent 3 4mm white round pearl beads (as shown in the picture).
Step 5: Make the Rest Part of the White Pearl Flower Pendant Necklace
1st, refer to the above steps to make 4 more such pearl leaf patterns;
2nd, thread a 4mm white round pearl bead and a 11x8mm pink faceted drop bead to a golden headpin;
3rd, add the pink bead pattern in the middle of the pearl flower. Then, thread a 10mm white round pearl bead and make a hoop on the other end;
4th, add the pearl flower to the middle part of the golden chain necklace.
Step 6: Here Is the Final Look of the White Pearl Flower Pendant Necklace.
What do you think of this white pearl flower pendant necklace? From the above description, it can be seen that it takes a little time and patience to DIY the white pearl flower pendant. But the result is rewarding. If you're interested in this white pearl flower pendant necklace, just follow the above instructions to make one for yourself or friends.
