Introduction: Build a "Tuned" Pipe for a 2-stroke
Please consider subscribing to my YouTube channel: Rusty Phoenix Motors
Two stroke engines fascinate me. They are so simple and fun that I've always enjoyed tinkering with them. There are many ways to boost the power, one of which is by installing a "tuned" pipe. The way a two stroke motor works causes them to be fairly noisy and a bit inefficient. A tuned pipe has a set of cones- Divergent (meaning the cone gets bigger) and Convergent (meaning the cone gets smaller) that are built to cause "echoes" or pressure waves to reflect back, which if done properly can increase the power of the engine. Check out this link, it will make a little more sense.
Animation of Two Stroke expansion chamber:
http://upload.wikimedia.org/wikipedia/commons/5/52/Arbeitsweise_Zweitakt.gif
As the pressure wave reflects back, it has a similar effect to turbocharging or supercharging a 4 stroke- it rams fuel and air that leaked into the pipe back into the cylinder under higher pressure, causing the motor to have more power (more fuel & air = bigger bang). That's a very loose explanation, but there you go.
I've always wanted to build an expansion chamber... This is where P.O.J. (pronounced Podge) comes in. This Piece Of Junk was (and is) my first motorcycle... found it in a grain bin around '95, back when I wasn't allowed to have bikes. Somehow, this one snuck home. I dug it out of storage a few years ago and began this process, so follow along as I make mistakes and learn a thing or two about building your own expansion chamber!
Please note, this is NOT the only way to do this. I think there is an easier way- done by cutting out two sheets in the correct shape, welding the edges, and the pumping ultra high pressure water in to "expand" the pipe, but I didn't have the tools at the time to do it like that. This is just how I did it...
Step 1: Equipment, Skills, and Supplies.
Skills you should have:
-Ability to Weld
-Ability to mark & cut metal ACCURATELY
-Understanding of and ability to use Shears, Brakes, and other metalworking tools
-Safe work ethic
-Understanding of 2 stroke engines
-Ability to use expansion chamber design software (OR, be really good at math or want to build 50 different pipes (trial and error))
-lots and lots of TIME
Supplies:
-Cold Rolled sheet metal- I used 18 gauge
-LOTS of welding rod- I used a 110v wire feed welder
-Rubber stoppers for isolation mounts
-Misc. nuts and bolts for mounting
-Duct Tape, shop towels, and band-aids. You never know!
Tools:
-Safety equipment- safety glasses, ear plugs, gloves, etc.
-Measuring & Marking tools- marker, scratch awl, steel rule, dividers, etc
-Squaring Shears
-Electric shears or aviation snips
-Hammer (ball pein works great!)
-Stake table with appropriate stakes
-Box and Pan Brake (could just use stake table but...)
-Welder (something capable of welding thin metal!) and related supplies- wire brush, clamps, gloves, helmet, safety gear, etc.
-Hack saw or metal cutting Band Saw
-Drill or Drill Press & drill bits
-Grinder and/or file
Other Usefull Things:
-2 Stroke expansion Chamber Software- I used 2 Stroke Wizard by Build and Click. Cost $20.00, came with a 4T header design program and a cone printing program that breaks large cones up to fit on 8.5x11 pages you can cut out and tape together. Great program. I tried a few free ones, but the first attempt at making a pipe from those didnt work so well...
-The Book Two Stroke Performance Tuning by A. Grahm Bell (apparently, not THAT A.G. Bell...)
-Someone who knows what they are doing, so you can ask questions! In my case, that was advrider.com
Step 2: A Little Groundwork Before You Build.
Here is a VERY basic rundown of what you need to do:
Before you can start at all, you have to know your port timing. Port timing is measured in degrees. You need a degree wheel, which you can print from here: http://www.1130cc.com/gallery/files/9/1/Degree360CCW.jpg
Remove the head from you engine. Remove the engine side cover over the flywheel.
Set the engine at Top Dead Center (TDC)- meaning the piston is all the way to the top of the cylinder as far as it will go. Attach the Degree Wheel to the flywheel, and align it with something on the engine or use a laser like I did. it doesn't matter where the wheel is oriented, as long as whatever it is oriented with is pointing at ZERO. See Picture 1.
Rotate engine slowly in the direction it runs until you see the top of one of the ports. Make a note of which port is opening and the degree at which it opens. Continue rotating, taking note of when the ports open and close. You will have to do some math to figure out the Duration- the amount of degrees each port is open- and then you are *almost* ready to plug numbers in to your software.
I did my port timing on Sketchup, which allowed me to draw lines at the degrees I measured, then use the protractor tool to measure the duration. The results are shown in Picture 3, with RED being the Intake duration, YELLOW the Exhaust duration, and BLUE the transfer port duration.
***Quick side note about 2 strokes- you will notice the yellow and blue are open at the same time. Exhaust starts escaping the cylinder, then fresh fuel and air is being pushed in at the same time which also helps push the exhaust out. The problem is that some of that fresh fuel and air also escapes out with the exhaust- which is the whole point of a Tuned pipe- the pressure wave is timed so that it will push most of that fresh fuel and air BACK into the cylinder through the exhaust port while the transfer port is closed but the exhaust port is still opened. Whew. Clear as mud!?
One more thing we need to measure before we can begin- Port locations and sizes. This is a little harder. There are lots of ways to do this, but I'm just going to share with you how I did it on my bike. It's, well, sorta unique...
Remove the cylinder as shown in Picture 4. you can see a few of the ports we need to measure. We need to know the height from the top of the cylinder, their location to each other, and their size.
Line the cylinder with aluminum foil as shown in Picture 5. Try to keep the foil as un-wrinkled as possible. Take a balloon or a laytex glove, stick it over an air hose, and set it in the cylinder. Inflate the balloon, causing it to push on the foil and indent the outline of the ports. Let the air out and take the balloon out. As you can see (barely) in Pictures 6 & 7, the ports have been imprinted on the foil. Unroll the foil, and measure the size & location of the ports. You can see my results in Pictures 8 & 9.
***Another quick note on 2 strokes- you can change the dynamics and power of a 2 stroke engine a LOT just with simple porting. I didn't mess around with the porting (yet), but a good port job combined with a tuned pipe work far better than just a tuned pipe by itself. Again, it depends on what you want the engine designed for- you can't have a high rpm road race engine that will also perform well as a lugging slow revving engine.
Whew. Got all the info we need, and we're finally ready to start the design!
Step 3: Designing the Pipe.
It was pretty simple to use the Build and Click software- fill in the blanks with all of the information you gathered, then click go and wait a minute or two. It spits out a nice sheet full of information including cone lengths and diameters at each end. Using that info, you can then make the cone printouts using the cone software that came with the program. Pretty slick! See the attached screen captures.
Step 4: Layout & Cutting
Once you have all of the cones and cylinder patterns, its simply a matter of tracing them on to your metal. I don't like making lots of cuts, so i tried to consolidate as much as possible by lining up long cuts with each other. You can see my finalized layout in Picture 2 & 3.
Once it's layed out on the metal, it's time to cut! This is where the Squaring Shears come in handy- its great for the long straight cuts (see Picture 4). I used a set of electric shears to cut out the curves, but aviation snips would probably do the job just as well (see Picture 5).
Once all of the parts are cut out, you are ready to start forming! As you can see in Pictures 6 & 7, I don't have the "header" or "stinger"- I used the stock head pipe cut to the length given in the design since it was the right diameter, and the "stinger" or last part of the pipe was so small in diameter I found a piece of pipe that was right and just cut it to length.
Ready to bend?!
Step 5: Forming the Cones- Slip Roller
Finished cylinder, ready to weld! (See Picture 8)
This works really good for straight cylinders, but its a little harder to do with a cone that will have different diameters on each end. I've been told a trick to this is to pinch the short end of the cone with pliers to hold it back allowing the longer side to get sucked through faster (see Picture 9). This didn't really work for me because my rollers were to big for the cones I was making anyways. I think with some practice, though, it would work really good.
The other option is to "micro-brake"- see the next step!
Step 6: Forming the Cones- Box and Pan Brake
Here's how:
Mark the cone by measuring each curve and then dividing the length by a set amount. For example, I decided on one of my cones I wanted to bend it every 7mm. I set my dividers to 7mm and marked that edge every 7mm. The OTHER end is a little more tricky. You need the same number of marks on the short end, so the marks are going to be a lot closer together. In my case, at 7mm I had 45 marks on the big end (see Picture 1). That means I needed 45 marks on the other side, which worked out to be a mark every 4.8mm. Its pretty simple math because you have all of the diameters for each side of the cone from the printout, you just have to find the circumference which ends up being the length of the arc you are working with.
***Quick note- on cones that have a big size difference, you may have to cut your number of marks in half or 3rds on the short side- meaning you will use a mark on the short side twice or three times before moving to the next mark.
Okay... So that may be kind of confusing. Lets put it this way- your markings will end up giving you a pie shaped section on the cone- always going down the center line of the cone.
Now we bend. Slide the metal under the fingers of the brake all the way until you can line up your first set of marks. Picture 2 shows a couple of bends done. ONLY BEND IT A TEENSY BIT!!! You can see in Picture 3 and 4 that I'm bending it too far. Not a real big deal, its pretty easy to straighten out.
Once you have the cone roughly bent (see Pictures 5 & 6) take some time with a hammer and the Stake Table to pound the cones into shape. The split needs to be as near perfect as possible to be welded. If I had taken more time on this one thing, my welding would have gone a LOT smoother! Get it as close as you can! See Picture 7 & 8. Picture 8 shows how close they should be for welding.
Finally. Time to melt some steel!
Step 7: Welding
How to weld thin metal
I feel the most important thing for making these welds work is to have the two pieces aligned as perfectly as possible. Doing butt joints like this means there is a lot of heat right on the edge of the metal, making it very easy to melt or blow holes through it. Not fun, or pretty. I spent some time with some scraps getting my welder dialed in correctly (see Picture 1)- take your time, practice, and figure out what works for you!
***Note on welders- I used a 110v wire feed welder with a thick flux core wire. Not the best setup for this situation. Ideally, a wire feed welder with argon gas shielding should work better for thinner stuff, or if you have access and the skill to use it, a properly set up TIG welder would be the best option. My first attempt was done with an Oxy-Acetlyne torch, mainly because I wanted to practice using it. It can be done, but some machines make life a lot easier!
Once you've got your welder figured out, the first step is to tack the piece together. Clamp the ends tightly as shown in Picture 2, then tack weld (just a small spot to hold it together) it about every inch as shown in Picture 3. Now for the hard part.
I tried a couple of different ways to weld this thin metal together, and the best way I've found so far is to "zappy-zap"... Kind of a variation on "skip welding". Skip Welding (see Picture 4) is when you weld a short strip, skip to a different section and weld another short strip, and keep repeating until the whole piece is welded. It worked okay, but I found that it would build up too much heat and melt holes in my project.
My solution was to do shorter and shorter skip welds, until my skip welds were about 1/4" long and took about 1 second to do. Then I started just zapping it for a second, pausing for a second to let it cool slightly, zapping it for a second again (just long enough to get a nice puddle to form to ensure penetration), then letting it cool, and just repeating the whole way down the joint. This ended up working really well for me.
Tips on welding thing metal
1. If at all possible, weld DOWNHILL. You travel faster and build up less heat, making it less likely to blow holes in your project.
2. On the "zappy-zap" welding- if you are still blowing holes in the metal, you can also weld a spot, jump ahead about 1/4" and weld backwards into the already welded spot. This way, the hottest part of the weld is over top of THICKER metal (because you ended on top of your previous weld) making it less likely you blow holes in it. Weld backwards, jump ahead 1/4", weld backwards, jump ahead, repeat...
3. If you do blow holes in your metal, using a filler rod for acetlyne or TIG welding along with your MIG welder can put enough metal in the hole quickly without getting it too hot and making the hole WORSE. Just hold the rod in your left hand, keeping it over the hole, and weld over top of it with the MIG welder.
Welding your expansion chamber
Individual parts: Pick one of the cones or cylinders and start by welding up the joint as explained above. I started with the belly of the pipe (the center cylinder). Tack weld it together, then weld it up. You can do one piece at a time and then weld the pieces together, or you can weld up all of the pieces and then weld the pieces together.
Joining parts: Again, I can't stress how important it is that the joints line up as perfectly as possible. If you took your time during the layout step, they should be pretty accurate, but you will have to do some tweaking to make sure the ends you are joining are both perfect circles and that they line up with each other. The stake table and grinder can be your friend here- just be sure if you grind anything it IS absolutely necessary. Once you are sure they are lined up, tack the 2 pieces together as shown in Picture 7, then clean up the burnt flux if you are using a flux core welder, and start welding! See Picture 8.
***Note on joining pieces- If things don't line up great, tack it together where it DOES line up, then use your hammer and stake table to "adjust" the fit. You can get things very close this way if you are patient...
Keep on adding pieces until you are done! See Pictures 9-13.
So you have a pipe... How the heck is this thing going to fit on the bike!?
Step 8: Making the Pipe FIT.
The HARD way (Pictures 2-5)
This is the way that was shown in A. Grahm Bell's book... And it's HARD. Requires a lot of thinking, planning, and way more welding. Goes like this:
1. Decide where you want the "bend" in the pipe.
2. Cut the pipe straight through.
3. On one side, starting at the widest point of the circle (the diameter) in the direction you want the pipe to bend, cut off a sliver at the angle you want the pipe to go. See Picture 2.
4. Weld the sliver back on to the same piece of pipe, just on the opposite side. See Picture 3.
5. Weld the other half of the pipe to the first half. See Picture 4 & 5.
6. Repeat for every bend...
As you can see, its very hard to get everything to line up nicely. I did the entire first cone this way, and was not pleased with the results. I ended up building a new first cone, and used the easy way on it. I feel it turned out MUCH nicer- and while it is more angular it was so much simpler to do.
The EASY way (Pictures 6-11)
Lots less cutting and welding.
1. Decide where pipe is to be bent and at what angle (Picture 7)
2. Divide angle in half (angle as measured from the centerline of the pipe, see Picture 8), cut pipe in direction you want it bent at half of the desired angle.
3. Rotate one of the cut halves of pipe 180 degrees, weld together (Pictures 10-12).
There are programs out there and if you enjoy math, you could sit down before you started building and figure out all of the angles for the cones and have done it in one fell swoop- basically eliminating this whole step. I don't enjoy math that much, and since this is a one-off project, it was easier to build the pipe, then cut and fit like this. Just keep cutting, welding, and test fitting (Pictures 13-15) to the bike as you go to make sure the pipe is going the direction you want it to go. My pipe came out better than I had hoped, but I do still think it could have been a lot better as far as fitting to the bike goes. Hey, its only my 2nd attempt, can't complain too much!
You can see in Pictures 16-29 How the pipe turned out. After I had experimented with both methods of bending the pipe, I went back and re-did the first cone of the pipe using the "easy" method, and it turned out much better.
Step 9: Mounting the Pipe.
To help absorb some of these vibrations, I built some "isolation" mounts. These are not true isolation mounts in that the bolt goes all the way through the rubber and bolts solidly to the frame. Basically, its just a large rubber washer that will hopefully absorb some of the vibrations.
Building the Isolation Mounts
1. Drill a hole through a rubber stopper- the hole needs to be big enough for the bolt and the stopper needs to be big enough for your application. See Picture 1.
2. Cut the stopper in half- it doesnt need to be that tall! See Picture 2.
Building the Brackets
Once you have the isolation mounts built, you can start figuring out where to place your pipe hangers. According to the books, the best way to build the hangers is to use the same metal used for the pipe, but layer it so that it's twice as thick. This way, you also have two tabs to weld to the pipe- one on each side. See Pictures 3-4.
You will need to build your bracket to fit where it needs to go- take your time and lots of measurements! If you are using isolation mounts, be sure to take into consideration that it's a lot thicker so the bracket will need to be out further.
Attaching the Brackets
To attach the bracket to the pipe, tighten the pipe to the cylinder and make sure the pipe sits where you want it to be. Tighten the bracket to the frame. Tack the bracket on to the pipe, then remove the pipe and finish weld the bracket. See Pictures 6 & 7.If you are bending or forcing the pipe or bracket into position, things aren't going to line up well when you remove the pipe and it can put pressure on the pipe causing it to fatigue and fail.
Place brackets so that no large section of the pipe is left hanging freely- again, thats inviting metal fatigue both from the engine vibrating and hitting bumps while riding. In these pictures, the entire back half of my pipe is hanging free. I plan to add another long hanger behind the brake lever, as shown in Picture 7.
Step 10: Testing, Notes, and Finishing
VERY important Note!- Any time you make changes to the engine, there will be a domino effect- you change one thing, other things are now no longer tuned right. As was brought to my attention by maxpower49, I forgot to mention the domino of putting on a tuned pipe. Since a tuned pipe will generally flow more air through it, the jetting in the carb needs to be changed to match. If more air flows through the engine with the same amount of gas, it will cause a lean condition which can be VERY bad for your engine!
This can be fixed by installing a LARGER main jet. With a custom job like this, it's a process of trial and error that involves a lot of swapping of jets and lots of spark plugs. It's safer to guess rich (too big on the main jet) and then move smaller in little steps than it is to go larger in little steps.
Here's the quick version of how to jet your engine: Make an educated guess (and guess on the rich or large size). Install the jet and a NEW spark plug. Start the engine, let it get good and warm, and then shut it off. It works best if you can actually ride it for a bit to put the engine under load. Remove the spark plug and compare to the chart in Picture 6. You want the tip of the plug to be a nice chocolate brown. White or grey or totally clean means it's TOO LEAN, you need a BIGGER jet. Oily and black means its too rich, and you need a SMALLER jet. This could probably be an entire instructable in itself. Hmmm......
Testing
While its running, take a moment to inspect for leaks. One problem with welding it the way I did, if I wasn't paying close attention I would miss a few pinholes. They are very easy to locate when the bike is running- the pipe is under pressure so anywhere there is a hole, smoke will jet out. Mark the holes if any and be sure to weld them up.
If you have access to a dyno, run some tests! If not, there's always the "seat-of-your-pants" dyno. I measured performance by speed- my bike would top out at 50 mph in 4th gear with the stock pipe. With the first pipe I built, it would hit 50 mph in THIRD gear, but the power band was so narrow that as soon as I put it in 4th the bike could barely hold 50 mph.
Once you are satisfied with the location and performance of your expansion chamber, make it look good! Not just because you spent so much time building it, but because its metal, and it WILL rust. Thoroughly clean the outside of any oil, dust, or welding debris. A wire wheel on a grinder works great! Use a HIGH HEAT paint and apply a few good coats to prevent it from rusting.
I haven't quite made it to this step yet, I'm still building the rearsets, kickstand, and custom brake lever for my bike.
There you go! I hope you have enjoyed this instructable on hand forming an expansion chamber. Please check back for finished pics and the seat-of-my-pants report on how the pipe works. My goal is to be done by JUNE! The pipe is done, I just have to finish up a few other odds and ends.
Step 11: Resources
Here is a list of things I found helpful during my build. I will probably be adding to this as I finish up my project and remember things I've forgotten...
Software
2 Stroke Wizard by Build and Click- http://buildandclick.com/html/all_products.html
Books
Two Stroke Tuner's Handbook by Gordon Jennings
(pretty sure you can find BOTH of these for free as .pdf's if you look around...)
Links
My original build thread with LOTS more info: http://www.advrider.com/forums/showthread.php?t=655547
Welding Tips and Tricks! http://www.weldingtipsandtricks.com/
Wiki on 2 strokes: http://en.wikipedia.org/wiki/Expansion_chamber
Misc
Degree wheel- http://www.1130cc.com/gallery/files/9/1/Degree360CCW.jpg
The OTHER way to build an expansion chamber:
More on Hydroforming exhaust: http://www.eurospares.com/frame8.htm
Expect an instructable from me sometime (not in the near future...) on how to hydroform an expansion chamber!
