Introduction: Change Furbys Clock With RadioWaves
Circuit-bending a furby. This hack make it possible to control furbys Clock speed with Radio Waves from Home appliances.
Step 1: Remove a Quartz Resonator From the Board
There is a quartz resonator (36.768kHz?) on the bord behind eyes.
Remove it with a soldering iron.
Step 2: Soldering Wires
Solder 2 wires (about 20cm) on the board where a quartz resonator was.
Step 3: Cut an Alligator Clips Wire Lead
Cut it in half.
Step 4: Soldering Wires on a 6P Toggle Switch
6P toggle SW, I named this SW as "Magical SW" in my video.
(left side) the quarts resonator <- STEP1
(center) purple lines are soldered on furbys board <- STEP2
(right side) Aligator Clips <-STEP3
Step 5: Check
when you close clips to Home appliances...your Furby may act violently or slowly !?
Have Fun !
Have Fun !
