Introduction: Cranberry Cookies
About: I helped start Instructables, previously worked in biotech and academic research labs, and have a degree in biology from MIT. Currently head of Product helping young startups at Alchemist Accelerator, previous…
Cranberry cookies make great Christmas cookies, but are also a great way to use up leftover fresh cranberries after the holidays.  These are my favorite cranberry nut swirl cookies -  they're well worth freezing cranberries so you can make them any time during the year!
These are great make-ahead cookies! You can freeze the rolled log indefinitely, then slice and bake the cookies whenever you like!  Then as scooch would say, you're only 12 minutes away from fresh hot cookies!
Fun bonus note:
these cookies won a cooking contest when I was 8 years old.  I made them with my grandma and my little brother, and we were pleasantly shocked to win first prize!  They've been a family favorite ever since.
Sneaky Valentine's Day mod:  pinch the cylinder of dough on one side, and poke it in on the other before freezing it to make a heart-shaped cross-section.  Delicious, and arguably romantic. ;)
Step 1: Ingredients
Dough:
1 stick unsalted butter
1/2 cup sugar
1 egg
1 teaspoon vanilla
1 1/2 cup flour
1/4 teaspoon baking powder
1/4 teaspoon salt
Sugary goo:
5 Tablespoons brown sugar
1 tablespoon milk (or cream)
Filling:
1/2 cup ground cranberries
1/2 cup chopped nuts (pecans, walnuts, hazelnuts, etc)
1 Tablespoon grated orange peel
Step 2: Prep Dough
Beat together:
1/2 cup sugar
1 egg
1 teaspoon vanilla
(I used my Kitchenaid stand mixer, but a fork, wooden spoon, or whisk will do nicely)
Then mix and add:
1 1/2 cup flour
1/4 teaspoon salt
This is a variation on a sugar cookie dough, meaning it will be reasonably thick.  Expect a consistency like a slightly greasy playdough.  (Of course, this dough is much tastier raw than playdough!)
Step 3: Wrap & Refrigerate Dough
Roll the dough into a flattened ball, and wrap it in plastic wrap.
Deposit it in the refrigerator to chill for at least an hour.
Step 4: Prep Filling
Filling:
2+ Tablespoons grated orange/tangerine peel
optional: pinch of your favorite spices (I used allspice and a bit of fresh-grated nutmeg)
I pulsed the nuts and cranberries (separately) in my cuisinart, and zested the oranges with my microplane.  You want identifiable bits of cranberry and nuts - not a paste, or distractingly big chunks.
Step 5: Prep Sugary Goo
Combine:
This should make a thick, syrupy paste that's just barely spreadable.
Step 6: Roll Out Dough
Roll out the chilled dough on a flexible surface.  I used a Silpat, but waxed paper, parchment, or plastic wrap are also fine.  You'll just need to be able to roll the dough up later without tedious de-sticking.  Don't flour the mat or your rolling pin - the dough is greasy enough that it shouldn't stick hard.
Roll and shape the dough to create a roughly 10"x10" square; the dough should be about 1/4" thick.
A handy note:  measure your hand span and other physical metrics for easy measuring and estimation.  Because I know my outstreached hand measures 9 inches thumb to pinky tip, it's easy to identify a 10-inch square.
Step 7: Cover in Sugary Goo
The title says it all!
Scoop the brown sugar mix and spread it over your dough.  Make sure you've coated the entire surface - it's the "glue" that will help keep your filling in place.
Step 8: Cover in Filling
Spread the cranberry-nut filling evenly over the sugared dough.
Leave about 1/2-3/4" clear at either end of the dough in preparation for wrapping.  This will keep the filling from bunching in the center of the roll, and allow you to properly seal the end and prevent dreaded filling explosions.
Step 9: Roll
Remember when I said to use a Silpat or other flexible sheet for rolling?  This is when it all pays off:  start rolling the silpat, and peel the dough off as you go.  Roll the dough into a cylinder, continuing to peel from the silpat as you progress.  This will get even easier as you go along.
Be careful not to introduce air bubbles, as this will create holes in your cookies.  The dough should be pressed gently but firmly against the filling - think cookie sushi.
When you reach the end, run your finger along the edge with gentle pressure to seal the end of the dough into the roll.
Step 10: Wrap and Freeze
Keep rolling your dough over right onto a sheet of waxed paper.
(If you rolled it out on waxed paper in the first place - bonus!)
Tuck the ends to avoid spilling any filling, and put the whole roll in the freezer.  If you're going to leave it longer than a day or two, add a layer of aluminum foil.
Step 11: Slice
Use a large, sharp knife (non-serrated) to cut the still-frozen cookie log into 1/4" thick slices.  This is about 6-7mm for you metric folks.
If the cookie roll cracks, let it soften a bit on the counter; if it mushes, return it to the freezer to resolidify.
Step 12: Bake
Spread the cookie slices on an ungreased baking sheet, and bake at 350F for 12-15 minutes until the edges are just golden brown.
These cookies don't spread too much, so 1/2" spacing between unbaked cookies is fine.
Step 13: Cool
Allow the cookies to solidify on the baking sheet for a minute or two, then transfer to a wire rack to continue cooling.
If the cookies deform or tear as you remove them from the baking sheet, wait longer before transferring.
Step 14: Serve and Store
I like these best served warm, with a cup of hot cocoa.  I'm told they're also good dunked in milk, and they're certainly delicious served cold.
To store:  cool completely, then store in a sealed container.  Like any good Christmas cookie, these are fine to make ahead and store for parties, but somehow mine never seem to last that long!
