Introduction: Curly Q Headband and Hair Scrunchies to Crochet
About: I crochet and do crafts. Oh and I also work full time and have a family to take care of. I'm on here because this site is so cool and easy to post to. You can also check me out on Ravelry: http://www.ravel…
I work out in the field, and I have really long hair.  Subsequently, I use headbands, ponytail holders and scrunchies to keep my hair in place and out of my face.  (Scrunchies are a fancy name for decorated ponytail holders, just in case you didn’t know.)
During the winter time when I have my hair down, I  use headbands, and I enjoy making my own, as I usually can’t find ones that fit my head or the outfit I am wearing.
Recently at my local craft store, I saw a new-to-me yarn that I picked up made by Red Heart called “Curly Q”.  Not knowing exactly what I was going to do with it yet, I picked out a color I knew would go with everything, and got to work making the two items shown in this instructable.
These are free crocheting patterns and I put the links to the yarn and hook size in Step 1.
There are patterns for an adult sized headband, a child sized headband, and Step 4 has a pattern for a hair scrunchie using a regular pony tail holder.
Step 1: Materials, Tools and Pattern Notes
Materials & Tools Needed:
1 Ball Curly Q Yarn – I got mine from Jo-Anns, the color I chose is called Calypso
Size P crochet hook (11.5 mm) - You can use a smaller or bigger hook, but you may have to adjust the stitches count.  See the note below about adjusting the stitches.
scissors and yarn needle
Additionally for the Scrunchies:
Ponytail Holders of your choice – I use the no-slip type.  Here’s a link to them on Amazon
Pattern Notes:
Skill Level: Beginner
Gauge is not important to this project.  More importantly is to use the type of yarn called for.  Because the yarn is stretchy, there is a chance that this pattern will not work for other 5-ply or 6-ply yarn.
This instructable assumes that you know how to crochet.  The special stitch is shown in this instructable for the type of yarn.
The yarn is stretchy which allows for the pattern to be used for different sized head circumference and different hair types.
I included a child-sized pattern as well as the adult pattern for your use and you can adjust the chains by groups of four (4) for the adult pattern and the child’s pattern if you don’t find the completed size fits your needs.
Be careful not to twist the foundation chain as you work.
First ch 3 is 1st dc of rnd.
First ch 2 is 1st hdc of rnd.
Abbreviations:
bpdc = back post double crochet; photo tutorial shown in Step 2 with this yarn
bphdc = back post half double crochet; photo tutorial shown in Step 4 with this yarn
ch = chain
dc = double crochet
fphdc = front post half double crochet; photo tutorial shown in Step 3 with this yarn
hdc = half double crochet
rnd = round
sk = skip
sl st = slip stitch
st or sts = stitch or stitches
yo = yarn over
Step 2: Crochet an Adult Sized Headband
Adult Headband Pattern:
Ch 24.
Rnd 1: Dc in the 4th ch from the hook, dc in next 19 ch, 5 dc in last ch, working in free loops on opposite side, dc in next 20 ch, (include the free loop of the same stitch), 4 dc in last st, sl st to top of ch 3;
Rnd 2: Sl st from front to back around ch 3 of first round, ch 3, working around bases of round 1, *sk next dc, bpdc around next dc, ch 3, * work from * to * to last dc in row before 5 dc group, skip 2 dc and bpdc around base of center dc st of 5 dc group, turn work and working on opposite side of rnd 1, skip 2 sts, ch 3, bpdc around next dc, ch 3 work from * to * to last dc of round 1, sk 2 dc, bpdc around next dc, sl st into first ch on first ch 3 group.
Fasten off leaving a minimum 8” length tail for joining.
Join ends together and using tail, whip stitch ends with at least 4 stitches.
Weave in all ends.
bpdc: yo, insert hook around from front to back around indicated st, yo and pull up a loop, yo and pull through two loops, yo and pull through last two loops on hook.
Step 3: Crochet a Child-Sized Headband
Child-Sized Headband Pattern:
Ch 22.
Rnd 1: Hdc in the 3rd ch from the hook, hdc in the next 20 ch,
Rnd 2: ch 1, sl st around last hdc made, ch 3, turn, working around center of hdc indicated of rnd 1, *sk next hdc, sl st around next hdc, ch 3, * work from * to * 9 more times to last st. (10 ch-3 groups)
Fasten off leaving a minimum 6” length tail for joining.
Weave in all ends.
Step 4: Crochet the Scrunchie
Scrunchie Pattern:
With first loop of yarn on hook, place hook through the hair band (ponytail holder),pull the hook and loop through the ponytail holder, yo the hook and ponytail holder..
Ch 2.
Rnd 1: 30 hdc around pony tail holder, sl st to top of ch 2,
Rnd 2: ch 1, do not turn, * bphdc around next st, hdc in between hdc sts in rnd 1, fphdc around next st, hdc in between hdc sts *, repeat from * to * around, join with a sl st to top of first bphdc.
Finish off and weave in ends.
bphdc: yo, insert hook from front to back of indicated st, yo and pull up a loop (three loops on hook), yo and pull through all three loops on hook
fphdc: yo, insert hook from back to front of indicated st, yo and pull up a loop (three loops on hook), yo and pull through all three loops on hook
Thanks for reading this and I invite you to come check out more of my crocheting patterns and work on Ravelry at DeandrasCrafts.
