Introduction: DIY Built-in Pop-up Flash Diffuser (soft Screen)
Well, if you are interested enough to read this post, I assume you know what a diffuser is so no need to introduce its purpose. It's just another version.
The idea is very simple, the image speaks for itself: a cloth-hanger-wire frame with a screen cut out from vacuum bag.
Step 1: Bend the Wire, Hang the Screen
While cleaning my closet, I found the cloth hanger is pretty strong, so I bend it to fit into the flash hot shoe, basically just a few trial and error. There are many wire sizes, some are too big and some are too small. You will know which one is the right one. I had 3 sizes of wire but only one made sense to me right away.
How you want it to cover the flash is up to you. I bent it into two arms so I can hang the diffusing material in front of the flash.
Important: try to bend the wire along the side of the flash hot shoe. Because the wire's plastic coat will eventually come off, you don't want to short-circuit the pins on the hot shoe base. In my case, the inner pins are lower than the surrounding, I just had to make sure the wire is straight and not curve down to touch the inner pins when I slide it in.
Canon (D)SLR: on the Rebel XT, I found a tiny switch on the right edge of the hot shoe to detect external flash. If I slide my diffuser frame in, the built-in flash won't fire. I had to bend the frame around the switch, it's less sturdy but good enough (unfortunately, I returned the camera without taking a picture of the modified diffuser frame to show here).
My Nikon D40 doesn't have any switch around the edge of hot shoe so there is no problem.
I tried different materials, keeping in mind that I need something that diffuses the light evenly, blocks least light, and is durable. Printing paper blocks too much light, while with tissue paper, you will need to bring a whole box for replacement.
The material I'm using is from a vacuum bag. Because the air has to flow through it, its transparency is somewhat equivalent to tissue paper, but it is super durable (much better than printing paper).
I folded a flap on the screen and tape it so that it's attached to the frame and the whole thing can fold flat in my bag. You might want to tape something reflective to the frame to save some light and prevent you from being blinded by the bounced flash.
Well, it's a small idea, nothing much to talk about.
Step 2: Sample Photos for Comparison and Thoughts
As requested, I took two quick shots of a kitchen, mainly because the flash is on top of my camera so I want something that has space below it to see the shadow (the microwave oven and handlebar of the pan).
Notice that the photo taken with diffuser is darker because part of the light was blocked by the diffuser although my D40 use TTL built-in flash. But it's not a big deal, it can be easily adjusted using software. The far right photo has been adjusted from the middle one using Level tool in GIMP. Also, I love the warm tone more than the flat white.
After two weeks of carrying the diffuser in my backpack (folded flat), sometimes it came out of the backpack with the soft screen completely crumpled, and the tape I used to hold it to the frame fell off. However, the material (vacuum bag) is so durable that I just straighten it and back to good again. I had another DIY soft screen before using normal printing paper and it couldn't withstand 4 times of coming in and out of the same backpack.
Step 3: More on Material
I just had a look at different vacuum bags in my house and realize that not all vacuum bags are ideal, so I should clarify on the one I used.
On the left is the genuine bag purchased at Menard. On the right is the cheap bag at Dollar store. Looking at the vertical space in the middle of each bag, you can see that the Rubbermaid bag is almost twice as transparent as the genuine one (obviously it's thinner). So, even though the Rubbermaid bag is not good for vacuum machine, it's ideal for a soft screen.
I also tested a tissue paper I found left after dinner. I took two shots: one with Rubbermaid vacuum bag, one with the tissue paper, and I couldn't tell the difference between them. The tissue paper is pretty strong too (it's from a big roll in the kitchen), but not as strong as the vacuum bag and is thicker.
