Introduction: DIY Folding Mattress Box
Please forgive me as this is my first instructable, thank you :)
After spending hours searching the internet, the only thing i found was how to build a platform for a mattress to sit on the floor. Saw a lot of cool ideas but none for replacing the absolute crap i had for a box spring. i have a bed already, needed a reliable box, something permanent. on top of that i have to be able to transport it a lot and get it around tight corners.
all dimensions are for my queen sized bed. all common dimensions are available on the internet, however make sure you measure your own bed several times to determine exactly what the dimensions should be for yours.
yes i fudged mine twice before i got it right. this is my success story lol.
if you have questions, can likely answer them.
thanks for checking out my creation and good luck on yours!
Step 1: Collecting Materials
sorry no picture for items...
for this box, i used:
18 cuts of 8"x1" untreated pine @ 39" (true measure is 7.25"x.75" board)
4 cuts of 8"x1" untreated pine @ 58"
4 hinges
8x corner braces
32x #32 1.5" bolts and nuts
32x small washers
64x 1.5" wood screws
7/64" drill bit
11/64" drill bit
drill
phillips/flat screw driver(or bits for drill)
socket wrench for the bolts
existing slats in bed frame
Step 2: Build the Frame
ok so i put the 39" boards on the ends of the 58" boards.
pilot 2 holes for the wood screws with the 7/64" bit into the top of the 39" into the end of the 58".
secure with 2 wood screws.
repeat on the other end of the 39" to another 60"
repeat again on the opposite end.
Step 3: Secure the Frame
here i used the corner brackets and the bolts.
position bracket in corner, mark holes for drilling.
remove bracket
use 11/64" bit to drill your marks
use washer for head of bolt, push through and secure bracket with nut
repeat for all holes and corners
Step 4: Add the Top Planks
here i used 7x 39" planks to complete the platform
position one plank on each end of box so that there isnt anything hanging over the edge
pilot 2 holes with the 7/64" bit on each end at the 39" plank
secure with 2 wood screws at each end
repeat on opposite end of box
position remaining 5 planks evenly across box
pilot 2 holes over 58" sides and secure on both sides.
ta-da! first box complete. repeat steps 2-4 to complete second box
Step 5: Attach the Hinges
turn up both boxes on the long edge with bottomes together
line up hinges on edges to minimize the gap but keeping the gap for the actual hinge
your new folding mattress box is now ready for operation!
Step 6: Sweet Sweet Sleep
unfold your creation onto your existing slats
cover with anything you like
add mattress and enjoy!
