Introduction: Fireball Shooter!
Make a flaming fireball shooter just like magicians use. Save $$ and MAKE your own! Awesome pyrotechnics effect! Safe to use indoors and out!
Step 1: What You Need...
1. 3/8-1/2" aluminum or copper rod. I used aluminum and got it at Home Depot. Cut to 3"
2. 1/4 X 28 nut - I had one in my parts bin
3. 1/2" Heatshrink tubing
4. 1.5v Glo-plug - Theater Effects
5. Flash cotton and flash paper.
6. JB Weld
7. Small zip ties
8. SPST Momentary Switch - Radio Shack
9. Butt splice
10. AA Battery holder and battery
6. JB Weld
7. Small zip ties
9. Butt splice
Step 2: Build the Shooter Body
Mix up the JB Weld and apply some to the rod and the nut and center the nut on the rod. Let it sit overnight to set. Thread the glo-plug into the nut. I used the heatshrink tubing just because it made the rod easier to handle plus it looks better.
Step 3: Build the Controls
1. Cut the black end of the AA battery holder and strip the end. 2. Solder a short black wire to one end of the switch.
3. Solder the short end from the holder to the other end of the switch.
4. Hot glue the switch on the negative end of the AA battery holder.
5. Run the zip ties through the battery holder. I cut an additional hole so they would loop through.
6. Attach the holder to the assembled rod.
7. Trim the ends of the butt splice and if you got the right size, it should snap on the end of the glo-plug.
8. Trim the red (positive) wire from the battery holder and put it in the end of the butt splice. Use pliers to squeeze the end of the butt splice and make a solid contact with the red wire.
Step 4: Prepare Your Ammo...
The flash paper and flash cotton has to sit overnight because it is shipped wet per DOT requirements. When it is ready, pull a small 1/2" square of cotton and fluff it up. Then tear off a small approximately 5" square of flash paper and roll it up in a ball. Push the flash cotton in the rod and then the flash paper. I used the eraser end of a pencil to push it to the bottom of the rod. Careful not to push too hard or you could damage the glo-plug. Press the button on the switch and FIRE AWAY! Experimenting with different siezes of paper will result in different effects! Have fun, be safe!
