Introduction: Flood Mood Light
Hi
This is my first Instructable, and when i started to make the project i never intened to place it on this site but the LED contest was too good to miss.
This is what the final product looks like.
Step 1: Prologue
As i said before i never planed to place this online so that means i did not take pictures when making the circuit, but i will walkthrough it as best as i can.
This project is aimed at people who dont have access to a microcontroller, but have expert experience with intergrated circuits and strip boards.
Finaly i want to say is, the way i have made this project is a prototype -Proof of concept- i dont recomend that you try to make this in the same way i have, i STRONGLY recomend using a printed circuit board because in some places you need very good fault finding skills to fix it, or when you do make it get a bigger strip board and space things out.
Step 2: Parts List
When i made this i bought the componnets as i went along because luckily, i live near RS Components.
Also the part list is for my circuit feel free to increase or decrease the size of the circuit to suit your needs.
100* 5mm RGB LEDs (36* used) ebay item number: 120426126311
2* Vero stripboards 100*160 holes
123* 470 OHM Resistors 0.5W
12* 1K OHM Resistors
6* 10K OHM Resistors
18* 2.2uF Capacitors
36* 1N4001 Diodes
24* BC635 NPN Transistors (In the instructable i acidentally typed in wrong transistors, now it has been changed. USE BC635)
6* 1K OHM Potentiometers ( I suggest you use a greater value 100K OHM)
3* 555 Timers
3* MC14017BCP Decade counter
2* Slide switch (on-on)
Tinned copper wire
Step 3: Useful Links
How to wire 555 timer in stripboard:
http://www.kpsec.freeuk.com/stripbd.htm
How to create a voltage controlled oscillator with 555 timer:
http://ecelab.com/circuit-vco-555.htm
How to wire decade counter:
http://www.doctronics.co.uk/4017.htm#Images_swf/4093_pins
MC14017 date sheet:
http://www.datasheetcatalog.org/datasheets/270/397492_DS.pdf
Step 4: Step 1: LEDs
Before i started i had planned that i will do each step one by one, and i will only continue once the step im doing is working perfectly.
So in this step i got out
5mm RGB LEDs
Vero stripboard 100*160 holes
In picture 1 you can see,
the LED that I bought has ground in the middle so when placing them into the stripboard be carefull.
In picture 2 you can see,
this is the most space efficient way of mounting the LEDs and the resistors
In picture 3 you can see,
one completed line the reason why i used 9 LEDs is because i ran out of room on the stripboard.
https://www.instructables.com/files/orig/F61/RW7N/GDM6U49Q/F61RW7NGDM6U49Q.jpg
(click here for bigger, better, more clearer picture)
In picture 4 you can see,
the completed LED part of the circuit, i only used 4 lines because of space but you can make up to 10 for one Decade counter.
https://www.instructables.com/files/orig/FSR/880U/GDM6Y6B3/FSR880UGDM6Y6B3.jpg
Step 5: Step 2: Fade
Step 2: Fade
In this step i wanted to create a way of fadeing off each LED.
So searching online i found this circuit.
The parts i used were:
1K OHM Resistors
2.2uF Capacitors
When i created my circuit i forgot to add the resistor on the trigger (image 1, R121) but i added it in later in a different part of the circuit
the purpose of that resistor is to reduce the sensitivity of the trigger because without it a small voltage will turn on the LEDs
In the picture 2 it shows,
how each fade circuit is created on a stripboard
also it is important to remember that there is a cut track underneath R1
In picture 3 it shows,
one completed line of LEDs with a fade circuit attached to the resistors
https://www.instructables.com/files/orig/F3Z/LAE9/GDM6U4BC/F3ZLAE9GDM6U4BC.jpg
in picture 4 it shows,
the completed circuit so far
Step 6: Step 3: Flood Control
In this step i wanted to choose the colour the LEDs where showing so i decieded to create a way of controlling each colour one by one.
In this step the parts i used where
1N4001 Diode
What i did was get a potentiometer and attached one side to positive the other to ground and attach the middle to 4 diodes which attach to a single colour
the reason for the diode is to stop multiple LED lines lighting up when not suposed to.
this step is alittle hard to describe but i belive the last picture explains it pretty well
Step 7: Step 4: Decade Counter
This step was easy but it was the hardest to put inside the circuit because i as running short of space to put all the compoenents.
The parts i used where:
10K OHM Resistors
2.2uF Capacitors
1N4001 Diodes
555 Timers
Important note  ***  you have to do this three times, one for red,one for blue and one for green ***
Creating the circuit below is easy
in the next step i will show you how to wire it to the triggers of the fader.
Step 8: Step 5: Putting It All Together
All you have to do now is put all the steps together and hopfully it makes sense.
But when reading over this i have a feeling that some people might be confused, so im going to make a picture of a circuit which only shows one colour. All you have to do is do it three more times.
The top bit, LEDs and fade is pretty simple to understand.
The bottom bit is harder.
The pink dotted line shows that you have to make this circuit three times (one for each colour) this is the decade counter.
The output  and input to trigger means,
because the decade counter does up to ten and i only have 4 lines of LEDs,
i have to double up the outputs
So here is a truth table.
output    I    trigger
0                   red 1
1                   red 2
2                   red 3
3                   red 4
4                   blank
5                   red 1
6                   red 2
7                   red 3
8                   red 4
9                   blank
This shows the lights really good with two output delay.
the light blue square shows a switch either select the flood control or the decade counter
the red square shows the flood control
https://www.instructables.com/files/orig/FBN/02HR/GDM73BPJ/FBN02HRGDM73BPJ.jpg
Step 9: Final Result
Here are some photos of the completed circuit
To view the bigger version of the picture like the small   i   symbol in the top left of the photo
Step 10: Schematic
for the brave ones who want to do this on a printed circuit board here are the files for
EAGLE 5.6.0
