Introduction: Hack a Dead HDD and an Angle Grinder Disk Into a Small Tool Emery Wheel
Step 1: Open Up
Here we have our HDD.
First we'll have to locate all the screws: a couple of them will be sealed away under white or "warranty void if removed" stickers.
Find 'em and remove all of them.
Open up, you might need to pry it open with a flat screwdriver, since many HDD producers use some kind of gummy stuff to keep the HDDs airtight.
Step 2: Strip It Down
Now we'll have to remove everything we don't need.
let's begin by prying off the upper support for the heads mount.
Now, pushing with your finger on the copper coil you just exposed slide the heads off the disk[s] and unscrew the bearing with a large flat screwdriver. They'll come rigt off, but you'll notice that they still hang to the HDD body by a flat wire.
Unscrew the evntual screws keeping the flat connector down and pull hard to remove.
Unscreew the rare earth magnet and store it for future projects.
Unscrew the 3 screws that keep the disk attached to the motor, and set aside along with the small disk, then lift off the main disk.
Step 3: Add the Disk
The angle grinder disk will not fit on the bearing, so we'll just lay it on and screw the small disk back in place.
Step 4: Power On
now you need to get power to the HDD.
I used an adapter that I had lying around in my wiring drawer, but you can also power it up by shorting the green wire with a black wire on an ATX power supply.
Step 5: Grind Away!
Here you have it. now you'll be able to sharpen scalpels, chisels, x-acto knives, regular knives, scissors, drill bits, coins, anything!
