Introduction: How to Install a Flexible Sign Post
Eliminate bent signs and sign replacement with our flexible sign post. The flexible sign post offers 360 degrees of flexibility and impact resistance. Installation is requires no special tools and only takes five easy steps. Drill and tighten your way to longer lasting signs.
Step 1:
Position the base of the flexible sign post in the desired location and mark the four base holes.
Step 2:
Drill the holes 6 inches into the ground using the power drill and ¾" masonry drill bit.
Step 3:
Place the mungo into the core of the holes that were drilled and hammer into the ground using the wide flat head hammer. Make sure the mungos are flush with the asphalt.
Step 4:
Secure the base of the flexible sign post by using the flex screw and the hex screw. (Make sure the base is aligned with the four base holes.)
Step 5:
Using the socket wrench with 15/16" drive, thread all four hex lag screws into the four drilled holes. Tighten until the head securely holds base plate in place.
