Introduction: How to Make Cheap Aluminum Wire Wrapping Dragonfly Ear Cuff With Blue Seed Beads
About: Hi, guys!! I’m Daisy. I love putting beads together to make jewelry work; sharing jewelry designs. If you like jewelry and beads, you are in the right place. I’ll regularly update new jewelry tutorials about b…
Wanna make wire wrapping earrings? If yes, you cannot miss today’s Pandahall tutorial on how to make cheap aluminum wire wrapping ear cuff earrings with blue seed beads!
Step 1: Materials Needed for the Wire Wrapping Earrings:
3mm Blue inside Color Glass Seed Beads
1.5mm Silver Aluminum Wire
4mm Blue Seed Beads
0.5mm Brown Copper Wire
Side Cutting Pliers
Flat Nose Pliers
Round Nose Pliers
Step 2: Make the Base of the Dragonfly Earrings
1st, draw the outline of the wire dragonfly and then twist the aluminum wire dragonfly according to the picture;
2nd, make the aluminum wire hanger according to the position of the dragonfly.
Step 3: Add Seed Beads and Wrap the Wire Dragonfly
1st, trim off a proper length of copper wire and wrap it around the head of the wire dragonfly several times, then add a 4mm blue seed beads on it and continue to wrap the wire on the opposite side;
2nd, continue to wrap the copper wire around the upper wings and then slide a 4mm blue seed bead on in the center.
Step 4: Continue to Add Seed Beads and Wrap the Wire Dragonfly
1st, wrap the down wings of the wire dragonfly wit copper wire and then slide two 4mm blue seed beads in the center;
2nd, continue to wrap the tail of the wire dragonfly and slide blue inside color seed beads until the length is enough.
Step 5: Finish the Wire Dragonfly Earrings
1st, add several seed beads on the tail of the wire dragonfly and then cut off the excess wire;
2nd, combine the wire hanger with the wire dragonfly with copper wire and then wrap copper wire around the wire hanger; 3rd, slide two seed beads at the end and trim off the excess wire.
Step 6: Here Is the Final Look of the Wire Dragonfly Earrings:
Wow, what a stunning wire wrapping ear cuff earring! Do you love it? The inspiration is from the column- Craft Ideas of our website www.lc.pandahall.com. Some fans wanna learn the tutoiral, so we do it for your reference.If you have any confusion, please feel free to ask me or leave a comment. Hope you a nice try and have a good time~
Step 7:
