Introduction: How to Make a Purple Quilling Paper Flower Necklace With White Pearl Beads Decorated
About: Hi, guys!! I’m Daisy. I love putting beads together to make jewelry work; sharing jewelry designs. If you like jewelry and beads, you are in the right place. I’ll regularly update new jewelry tutorials about b…
This article is about a purple quilling paper flower necklace. It's not very difficult to make the purple quilling paper flower necklace. Just check the tutorial below.
Step 1: Supplies Needed in DIY the Purple Quilling Paper Flower Necklace:
DIY Paper Quilling Strips Sets
10mm White Round Pearl Beads
8mm White Round Pearl Beads
6mm White Round Pearl Beads
White Flat Round Pearl Cabochons
Iron Cross Chains
Silver Jump Rings
Silver Headpins
Silver Eyepins
11.5x6mm Silver Round Magnetic Clasps
Needle Nose Plier
Round Nose Plier
Rolling Pen
Tweezers
White Glue
Step 2: Make the First Part of the Purple Quilling Paper Flower Necklace
1st, cut a piece of purple quilling paper and use rolling pen to make a circular pattern (as shown in the picture);
2nd, use white glue to fix the circular pattern and glue the ends (as shown in the picture);
3rd, make the circular pattern into a drop pattern (as shown in the picture);
4th, refer to the above steps to make more such drop patterns (as shown in the picture);
Step 3:
5th, use white glue to combine 5 purple drop patterns into a flower (as shown in the picture);
6th, refer to the above steps to make two more purple quilling paper flowers (as shown in the picture);
7th, use white glue to glue a white flat round pearl cabochon onto the middle part of the three purple quilling paper flowers respectively (as shown in the picture).
Step 4: Make the Rest Part of the Purple Quilling Paper Flower Necklace
1st, combine a 10mm white round pearl bead, 3 8mm white round pearl beads and 5 6mm white round pearl beads with silver eyespins one by one(as shown in the picture);
2nd, make a hoop on the other end of the silver eyepins. Then, combine 3 6mm white round pearl beads with 3 8mm white round pearl beads. Then, combine two 6mm white round pearl beads together(as shown in the picture);
3rd, refer to Step1 to make 7 more purple circular quilling paper patterns (as shown in the picture);
4th, add a purple circular quilling paper patterns on the two sides of a purple quilling paper flower. Repeat this step once. Then, add the other three purple circular quilling paper patterns to the other purple quilling paper flower(as shown in the picture);
5th, add the 10mm white round pearl bead to the hole of the purple circular quilling paper pattern through a silver jump ring(as shown in the picture);
6th, add the other two purple quilling paper flowers and two 6mm white round pearl beads pattern through silver jump rings (as shown in the picture);
Step 5:
7th, add the 6 white round pearl beads pattern to the hole of the other purple circular pattern through a silver jump ring(as shown in the picture);
8th, cut two parts of silver twisted chain ( about the same length) and add them to the two sides respectively (as shown in the picture);
9th, combine the two ends of the purple quilling paper flower necklace together through an 11.5x6mm silver round magnetic clasp and two silver jump rings(as shown in the picture).
Step 6: Here Is the Final Look of the Purple Quilling Paper Flower Necklace.
What do you think of this purple quilling paper flower necklace with white pearl beads decorated? The purple quilling paper flower necklace looks very elegant. The three quilling paper flowers are not difficult to make. Just collect some materials and give it a try!
