Introduction: How to Tie a Tie: Windsor Knot
About: #morehouse20
Here's are the step by step process of tying a tie.
Step 1: Gather Your Materials !
Pick your favorite tie you would be wearing.
Step 2: Sizing Up!
Make sure the thicker side is on your left shoulder and the thin side is on your right.
Step 3:
Begin by crossing the thick end over the thin end.
Step 4:
Then repeat step number 3 once more.
Step 5:
By now you will begin to see the form of the tie knot.
Step 6:
Pull the thicker end up and over to freely lay on top of the knot.
Step 7:
Next you will need to pull the thicker side through the knot as seen above.
Step 8:
At this point in the journey you're going to being to tighten the tie up on your neck.
Step 9:
Step 10:
Next you would be taking the thing end and applying it to the slot on the back.
Step 11:
This should be the end result after adding the thin end into the slot on the back end of the thick end.
Step 12:
At last we have come to the end of the journey of tying ties.
