Introduction: How to Build the One Motor Walker!
About: I am a French Canadian that loves robots and embedded electronics. I work on all kinds of cool projects, like a high-power electric push scooter controlled with an Arduino. Please visit my website for more co…
Welcome!
Here is Instructables on how to build a walker with only one motor! This design is base
on the principal of B.E.A.M robotics! Building simple and elegant robot inspired by insect.
This robot was build back in 2000 and want to show you how to build it.
Beware this is a complex project!
This project incorporate two more instructables
How to modify a servo motors.
https://www.instructables.com/id/How-to-modify-a-servo-motor-for-continuous-rotatio/
How to make the bicore circuit.
https://www.instructables.com/id/How-to-freeform-the-bicore-BEAM-robotics-/
( I still did not learn with those truncated title :P )
Here are the 3 most important steps in this Instructables
step 1 - Read carefully!
step 2 - Read again before asking questions, check the comments!
step 3 - Did you read? if not goto step 1
PS- My instructables don't even contain a lot of text! Just pictures! :)
To be able to make this robot you need skills.
You will need to solder electronics components.
Gareth Branwyn once contacted me to make a article in his book about my one motor walker.
The chapter is online. This is worth reading in parallel while making the robot.
http://solarbotics.com/products/abg/
Solarbotics made your life easy by making custom bundle for you!
http://solarbotics.com/products/abgchw/
I don't think there is a big gear is in there. Be careful.
If you never build a robot and want to tackle the one motor walker, I suggest you try the beetle robot.
https://www.instructables.com/id/How-to-Build-a-Robot-The-BeetleBot-v2-Revisite/
Good luck!
Jerome
Don't forget to check my website to see my latest projects!
www.JeromeDemers.com
Step 1: How to Build the One Motor Walker!
Here is what you need to build this walker.
Items for the robot:
1 x Servo motor with servo horn
1 x Terminal block
1 x plastic gear ~2 inch
1 x plastic servo horn
1 x 2 feet of 8 to 10 gauge wire ( can use coat hanger wire or 10-gauge copper wire )
1 x short piece plastic tubing ( can use the isolation from the 8-10 gauge wire )
2 x AA or AAA battery holder
You could use the GM8 from solarbotics
http://www.solarbotics.com/products/gm8/
don't forget this
http://www.solarbotics.com/products/gmw/
Items for the BICORE"
2 x .22 µF monolithic capacitors
1 x 100K to 10MΩ resistor (we recommend 3.2MΩ)
1 x 74HCT240 integrated circuit (IC) 74AC240 will be better
1 x 20-pin DIP IC socket
1 x on/off toggle switch (smallest you can find)
the recommended tools for this project:
1 x safety glasses!!
1 x soldering iron
1 x glue gun
1 x wire strippers
1 x side cutter
1 x scissors, knife, x-acto, etc
I recommend you to take the time to read this entire instructable before starting. In every page I have added a lot of pictures, so don't forget to look.
Step 2: How to Build the One Motor Walker!
This is main mechanical part you will need to make the robot.
You can find this sort of gear in VCR. Search garage sale or ask familly and friends.
The DVD is already obsolete thank to the BluRay, imagine how obsolete is the VCR! :P
The gear in the picture is from a VCR.
If you are really lazy, you can buy it from there
http://www.allelectronics.com/make-a-store/item/GR-5/SET-OF-5-GEARS-AND-BUSHINGS/-/1.html
Step 3: How to Build the One Motor Walker!
Glue the servo horn to the plastic gear. Be sure both hole are aligned.
You can use traditional servo horn for this project. It will work.
Step 4: How to Build the One Motor Walker!
Please visit this instructables to know how to modify a servo motor
Step 5: How to Build the One Motor Walker!
Here you are building the pivot rod for the front gear.
I took a coathanger and bend it like the second picture.
You simply glue it in place.
You can use cooper wire to do the same thing. Look at step 8 to know which wire to take.
Step 6: The Front Gear
Find a rigid plastic tubing that fit over the coat hanger. This tube is your pivot.
You can use the plastic that cover a electric wire. Maybe some 14/2 or 10/2 wire will do.
Read step 8 to understand what does 14/2 mean.
Step 7: The Gear Assembly
This is a easy step. You insert the front gear into the metal rod.
Bend the rod so both gear touch. This is really important.
To secure the gear, look at the step 9. I use terminal block to hold it place.
Step 8: The Legs
Find some 14 gauge cooper wire. It is normally call 14/2 or some will say 2/14
8 to 10 gauge will work too.
14 is the gauge ( the size, the diameter of the wire )
22 gauge is breadboard wire and gauge 0 is the size of your finger! 200 Amp
2 is the number of wire not counting the ground. You have a black and white wire.
The black wire is the "hot" that carry the 120V
14/3 is the same with one more wire. The wire is red. You normally use this wire when you have
a 3 way. Two switchs that control one light for example.
You can use a coat hanger to make the legs.
I recommend adding to some heatshrink to the end of the led to have better grip on the floor.
You can see on the video, the robot slips a little bit while walking on the table. There is no heatshrink on my robot, only rigid plastic tube.
Step 9: The Battery Holder
I use AAA batter holder but AA will do the same. Glue them to the servo motor.
We will hook are battery holder in serie to get higher voltage but with the same current.
Four battery of 1,5Volts will give 6V of power.
If you use rechargeable battery it will be 4,8Volts
To hold your gear in place, I have use some terminal block, I have remove the plastic and cut the terminal in two using a saw. I simply put them on the shaft to hold the gear.
You can even use small tie-wrap instead of terminal block.
Step 10: The Circuit
This is a the hard part if you never made electronics.
Please visit this instructables to make this circuit
The schematic is really ugly and was made ~7 years ago with paint!
The 74AC240 circuit come from www.beam-online.com
R1 = 1Meg Ohm
the capacitor are 0.22uF
Step 11: How to Build the One Motor Walker!
Glue the circuit on top of the servo.
Hook up the motor to the circuit like the circuit.
Step 12: How to Build the One Motor Walker!
You robot is finish.
