Introduction: How to Make a Kydex Holster for a Gun DIY
About: Ever since I was a kid I liked to build stuff, so now as an adult I like to use my talents as hobbies, while still have to maintain a job for income. Some of the things I like to work with is, wood, metal, Kyd…
http://www.youtube.com/watch?v=l1hYtSZzEs8
This is a video of How-To make a Kydex holster for your gun.
For more details go to my YouTube channel  SlavicFMJ, I have a video of me making it.
 http://www.youtube.com/watch?v=l1hYtSZzEs8&feature=share&list=UUXnhdsjtN34xBT0olCHmsYA
Materials:
2 x Sheath/Holster Making Foam - Thermoform Molding - (Mega Form) - (12x11.5x1)
9 x Eyelets - #8-9 (1/4) - Gunmetal Finish - (for .080-.093 KYDEX™)
1 x Hand Setter Kit - (#8) - (for 1/4 inch sheath rivets)
4 x Chicago Screws - Black Oxide - #8 - (.1875 x .250) -
1 x KYDEX™ Sheet - Black - (.080)
Step 1:
Tools:
- heat gun
- oven
- set of screwdrivers
- drill with 1/4 inch bid
- Dremel with stone/sand paper attachment
- 150, 300 and 500 grip sand paper
Step 2:
Anyhow. In the video I talk about what I made and how but a few things I left off and they are not in order:
How to set in rivets/eyelets:
Use a punch kit that I have in description. It consists of a metal base and a metal punch. All you have to do is to put an eyelet through your sheet of Kydex, then set it on a base and punch on the other and hit a few time until rivet will expend and look good.
How to sand down the edges:
Use low grit sand paper at first and make your way up to a 500 (fine) and make sure you sand down all the sharp corners EVERYWHERE.
Step 3:
How to make belt loops:
This one I forgot to film, so read carefully. First decide what size of a belt you want to use it with. For mine I had a 1.75 inch width. So that means I need my loop to be in rectangular form 1.75'' long and 3/4'' wide and 0.5'' thick.  So to make them I cut out a peace of wood size of 1.75'' wide and 0.5'' thick (length doesn't matter) so then I took my heat gun and heated up a strip of kydex of the right size with some room to spare and after you get kydex to about 300 F it becomes really soft and you just wrap around your piece of wood and in a few minutes it comes out the shape you want. (if this a sucky description, I'm sorry, English is not my first language)
Step 4:
How to bend the edges of a holster:
Very easy. When you holster about to be done and all is left is to curve it to the right angle, use a heat gun and warm up the edge you want to bend (not Hot but warm) and gently force it to bend where you want it to bend.
If I missed anything or if you need more explanation, let me know and I will make sure to help answer your questions.
Thanks!
p.s. It's my first instructable. More to come.
