Introduction: How to Make a Sculpted Hellboy Cake
About: Hello! I am an artist who has decided to try cake decorating after a close friend suggested it. I have been making cakes since August of 2010. I'd watched a lot of the various cake shows on TV and decided to t…
Hello everyone!
This is the cake I made for my first cake show competition. It was for That Takes The Cake 2011 in Austin, TX. I've onyl been making cakes since August 2010 and this is still just a hobby for me until I get the funds to get everything I need to start up a business and I'm self-taught so I'm super happy that I even placed in the top 10 at the show. I came in 8th!
I had a lot of issues and mistakes but I learned a lot and am now planning and starting my next sculpted cake for a show at the end of April.
The theme for the Showcake category at That Takes The Cake was Super Heroes and Villains from comics, books, movies and TV. I chose to make Hellboy because I love Mike Mignola's work, as well as the movies and loved Ron Perlmann as Hellboy.
Depending on your artistic skill, this could be hard or easy. Towards the end of this cake I didn't get as many photos, as I was behind on time, but I hope this Instructable can at least give you the basics on how to make this!
The head and arms are rice cereal treats and the rest is Devil's Food cake (felt that was fitting for Hellboy) covered in fondant and then detailed and hand painted with gel food colors. One of my mistakes was hand painting the skin and base. I hadn't yet learned to use the airbrush I recently bought and was out of time so I hand painted it and it came out really splotchy, with brush marks and was way too wet and shiny for way too long. I would definitely recommend using an airbrush! Although the texture was great for the coat.
I also didn't build up the shoulders and I should have, as once the heavy fondant was on they shrunk in. Also didn't use enough support dowels and separators inbetween every few layers so his body started to settle and compress down with the weight of the cake (this is the biggest cake I've ever made, learned a lot!) but his head and top of shoulders were made out of the rice cereal treats and stayed up on the supports, so he eventually came apart, starting even before judging. The 4 hour drive to the show I think hurried the process along.
Here's a list of general supplies I used to make the cake:
• Cake pans for baking the cakes. I used a quarter sheet pan for all of the cake.
• General cake decorating supplies: Mixer, spatulas, turn-table, carving/clay/fondant/gumpaste tools, matt to roll fondant on, fondant rolling pin, gel food colors, knife, cake leveler, toothpicks, food-safe paintbrushes, small containers to mix food color "paints" in, tape, cake support dowels, etc.
• Ingredients to make cakes, buttercream icing, fondant and to mix food colors with (you will mix the food colorings with something like vodka or clear vanilla extract, not water.)
I had to make a wooden base to support such a heavy cake so I've shown that in this Instructable too. I used two 24" x 24" x 1/2" plywood pieces, and a larger wooden dowel and wood screw and then a pack of wooden cabinet knobs as the feet, so that it would be easier to get fingers under the heavy cake and board.
Here's the link to the alterations made to a box cake mix to make it a little stronger to better support sculpting. I altered this recipe a little, adding an extra egg and an extra half cup of flour.
http://cakecentral.com/recipes/7445/the-original-wasc-cake-recipe
Here's the link to how to make the marshmallow fondant, which is pretty yummy, although very sweet! Pre-made fondant can be bought if you do not want to make the marshmallow fondant but beware that some of the pre-made doesn't taste very appetizing. Two brands that do taste good are Satin Ice and Fondx. I've used the Wilton once before and it's not too great tasting.
http://www.wilton.com/forums/messageview.cfm?catid=7&threadid=137541&FTVAR_MSGDBTABLE=
Here's a simple recipe for the buttercream icing, a 2 lb batch. This uses shortening in place of butter. I'm in Texas and butter doesn't hold up as well. If you don't have a stand mixer or don't want to make your own icing you can buy some pre-made.
Ingredients:
2 Cups Shortening
2 lb bag Powdered Cane Sugar (or approx. 8 Cups)
4 TBSP Meringue Powder
2 tsp Vanilla Extract (use clear vanilla if you want your icing to be white)
2 tsp Butter Flavor (use clear flavor if you want your icing to be white)
1 tsp Almond Extract
Water
Directions:
Sift together powdered sugar and meringue powder into large bowl. Set aside.
Mix the flavor extracts together in a measuring cup. Add enough water to the mixture to bring the amount to 1/2 a cup. Put this into a mixer bowl with the shortening.
Add about 1/4th of the sifted powdered sugar/meringue powder mixture to the shortening and flavors in the mixer bowl. Beat on a slow speed with the paddle beater and the slowly incorporate the rest of the powdered sugar mix into the mixer bowl as it's slowly mixing. Once it's all in there I usually turn it up a notch in speed for about 1 1/2 - 2 minutes. Then it's done!
Keep it covered until you are ready to use it, as it will "crust" over if you are not ready to use it and leave it uncovered to the air.
Step 1: Making the Base
To make the base to support such a heavy cake, I used two pieces of 24" x 24" x 1" plywood. I rounded off the edges of both boards, rounding the front edges more. The display table at the show was rounds so I wanted the base to be rounded off. I then glued them together with wood glue and nailed them together.
You can see an extra strip I added on the back egde. That was to be for some elements that I had to omit due to time constraints so that can be ignored. :)
Once it was together, I sanded it all down. Then I drilled a hole in the center where I wanted my main support dowel to be, the same size as the wood screw shaft, but smaller than the screw head. For this support dowel I chose a 1/2" dowel, 24" long since the minimum height for the competition was 24". I made a small hole in one end with a small drill bit. Then I pushed my wood screw through the hole in the base from the bottom and screwed on the support dowel.
Once done I added some plain wooden cabinet knobs I found at Walmart that came in a pack of ten. I drilled small holes in the base where I wanted the feet to be and then attached them with wood screws.
Step 2: Covering the Base With Fondant
Next I made a large batch of the fondant and covered the base with it.
After making the fondant and setting it aside, all wrapped up so it wouldn't dry out, I brushed on a layer of piping gel to the top of the base and sides and about an inch over the edge on the bottom. This gives something for the fondant to stick to.
I rolled out the fondant and layered it on the base in several pieces, as I couldn't roll a big enough piece to cover the whole thing in one piece. This was OK though since I was going to cover over the seams where the pieces met.
After this was done I rolled out the rest of the fondant and cut random tapering, curving strips and layered them on top of the fondant covered base, radiating out from the center support, mostly in front. These fondant pieces were "glued" to the fondant on the base by brushing some water on the backs of them before putting them down on the base.
Step 3: Stacking and Carving the Cakes
Before I stacked the cakes on the base, I covered the base with plastic wrap, leaving a rectangle of space around the dowel uncovered, so that I could apply icing there before stacking the cakes so that they would stick to the base. The reason I covered the base is so that when I was carving the cake, covering it with icing and fondant, the fondant bas wouldn't get messed up by cake crumbs and icing.
I stacked the cakes, with buttercream in between the cakes. Every 4 cakes I would insert smaller dowels, cut to the same height of the top of the top layer cake, then cut down a carboard cake board, cover it with wrap, and place it on top of the doweled cake, to help support it. I should have done this better, and with every two cakes instead of every four, and used slightly bigger and thicker cardboard. Perhaps using hot glue to glue a few cardboard cake boards together. Still learning about cake support and this was definitely a learning experience!
I ended up using 10 quarter sheet cakes. I also was trying to use up all the leftover icing I had made from my cake decorating class so that's why it's multi-colored. :)
Next I shaped the stacked cakes a little with a knife. I had tons of Hellboy reference photos printed out and layed on the counters so I could look at them easily.
Step 4: Shaping and Adding the Head and Arms
Next I made a triple batch of rice cereal treats, using the recipe on the Rice Krispies box (also on their website) and used them to shape his head and arms.
Didn't get photos of this process as while doing it my hands were lightly coated with Crisco so that the treats wouldn't stick to my hands and I didn't have time to keep stopping and washing off my hands to take photos. :( I was running behind!
I formed the pieces around the smaller cake dowels, with parts of the dowels sticking out so I could push them in to the cake when attaching them.
Again I had photos all around me while doing this for easy reference.
Step 5: Covering the Cake With Icing & Fondant
Next I covered the cake and cereal treat with buttercream icing. That gives the fondant something to stick too and helps get smoother coverage, a little "padding."
After covering with icing I rolled out fondant to start covering. Again, here's where the Instructable kind of ends, as by this time I was way behind and needed to finish so we could make the 4 hour drive to the show.
I covered it in pieces. Working "background to foreground."
First I covered all the showing skin areas and head (minus the sideburns and the horns) and sculpted and detailed them along the way before they dried out too much. I had made hollows for the eyes and after it was covered added the eyeball and eyelids separately.
Next I did the pants, then belt and horseshoe and rosary.
Next was the lower portion of the coat, then the sleeves, then the upper portion of the coat.
Last was to add the ears, the sideburns of the hair and horns.
I used gumpaste/fondant tools for all the detail.
After it was finished I painted it with Wilton food colors mixed with vodka. you can use either vodka, clear vanilla or other clear flavor extracts, or other clear alcohol to mix the colors with. Water makes fondant gummy and too much will ruin it so you want to use water as glue and alcohol to paint with, as it will evaporate, leaving behind the color and not ruining the fondant.
After the show was over I kept the base, to reuse, and the head since it was rice cereal treats. I took some better photos of the head after I got home. Still splotchy but dry at least!
