Introduction: How to Unclog a Blocked Toilet Without a Plunger
What would you do if your toilet got clogged on a Saturday evening when the shops are closed and you are about to host a curry and beer party?
This instructable will show you a simple method for unclogging a toilet using hot water and shampoo. While there are other methods of clearing a toilet drain, this is a great option for unclogging a toilet because you don’t have to touch the water.
You will need:
- 1 clogged toilet (works best when someone has been overzealous with the toilet paper)
- A generous amount of surfactant (i.e., Dawn Dishwashing liquid, shampoo, liquid soap, or any other cleaner that gets sudsy)
- Hot (but not boiling) water
- A bucket or a basin to transport water to toilet
This will only work with a toilet that is not overflowing and has some room to hold extra water.
(For squeamish people: The picture of the blocked toilet was not created with actual bodily excretions.)
Step 1: Add Shampoo and Hot Water.
Get your bottle of shampoo/ soap and squirt a generous amount into the bowl.
Follow that with a bucket of very hot water from the hot tap (not boiling).
Fill the toilet full but not overflowing.
The reason you should not use boiling is because it has been said that boiling water can cause the toilet bowl to crack (I have not personally tested this assertion though as I do not have the money to buy a new toilet).
Then go have a cup of tea and let the blockage 'marinate'.
Step 2: Return and See Your Handy Work.
Hopefully after a few minutes the water level will have lowered. (Hot water helps break up toilet paper quicker and the soap lubricates the passage of solid material).
If nothing has happened wait 10 minutes more. If still nothing has happened you will probably need to use a different method (or bail some of the water out and add more hot water/ soap).
If the water level is lower than before add more soap and more hot water (hot water does not need to be as hot as the first time as this time there is less water in the toilet to heat up).
Again wait for water to drain (this should be quicker).
Repeat the process until water flows freely.
Step 3: Done
Done.
Remind your party goers to treat your toilet with respect and only put bodily excretions and small amounts of toilet paper in.
Fix It Contest
