Introduction: Latest Pearl Necklace Design - How to Make Long Layered Bead Necklace With Chain
I love long layered pearl necklace with chain. So, I want to share you how to make layered bead necklace with detail steps. Hope you will like it!
Step 1: Materials Needed in Beaded Long Fashion Necklace Designs:
4MM Ivory Glass Pearl Beads
6MM Ivory Glass Pearl Beads
8MM Ivory Glass Pearl Beads
Eyepins
Chains
Lobster Clasp
Jump rings
Step 2: Make Bead Links for the Layered Pearl Necklace With Chain
1st, use an 8mm pearl bead and an eye pin to make an 8mm pearl bead link;
2nd, make another eighteen 8mm pearl bead links in the same method;
Step 3:
3rd, make thirty-five 4mm pearl bead links and twenty-one 6mm pearl bead links again.
Step 4: Make Bead Link Chain for the Long Layered Pearl Necklace
1st, connect 10 bead links together to make a bead link chain, the specific sizes and order of the bead links are as follow: a 4mm bead link, a 6mm bead link, a 4mm bead link, a 6mm bead link, an 8mm bead link, a 4mm bead link, a 6mm bead link, a 4mm bead link, and a 6mm bead link;
2nd, make another three 10-bead link chains in the same way;
Step 5:
3rd, connect 7 bead links together to form a bead link chain, the specific sizes and order are as follow: a 4mm bead link, an 8mm bead link, a 4mm bead link, an 8mm bead link, a 6mm bead link, a 4mm bead link, and an 8mm bead link;
4th, make another four 7-bead link chain in the same way.
Step 6: Finish the Latest Long Layered Pearl Necklace Design
1st, cut 8 pieces of silver chain as the length of 7cm;
Step 7:
2nd, use a silver chain to connect a 10-bead link chain and a 7-bead link chain;
Step 8:
3rd, do the rest 7-bead link chains and 10-bead link chains in the same method until you get a long chain, remember to keep a silver chain between a 7-bead link chain and a 10-bead link chain as picture shows;
4th, cut two 7cm silver chains again, attach them to each end;
Step 9:
5th, use jump rings to connect a lobster clasp to both ends.
Step 10: The Final Look of the Layered Pearl Necklace With Chain Looks Like This:
Fantastic! This latest long layered pearl necklace design is done! What a fabulous long layered pearl necklace and a perfect formal accessory to wear everywhere! Based on this tutorial, you must know how to make layered bead necklace. You can match the beads and chain as you like, such as turquoise beads and gold chain. Have a nice try to make a long layered necklace with chain!
