Introduction: Lippage Free Tile Installation Instructions
About: I am a general contractor and the owner of A2Z Sell - A web store for home remodeling tools and accessories.
ATR Tile Leveling And Tile Alignment System
Go lippage free in your tile installation. Tiles that may seem perfectly leveled during installation, often show a difference in height after the thinset cures and in many cases, extreme lippage may affect the aesthetics of your flooring and is also potentially a tripping hazard. Accurate tile setting requires perfect leveling of the tiles. It is often hard to properly set ungauged and thin tiles as well as larger and thicker tiles because of uneven floor foundations. This is the problem you can avoid with the ATR system - using the ATR leveling system you can quickly achieve a smooth leveled surface.
The ATR leveling and alignment system is very easy to learn and use at any skill level !!!
This Tile Leveling system is a 2 parts system (Spacers And Spindles) and does not require the use of additional, expensive tools. Everything you’ll ever need to level medium to large format tile and stone is included with this system, using only your hands!
ATR Tile Levelers Benefits:
• Drastically reduces the need for grinding and polishing of surface.
• Reduces installation time and improving cost-effectiveness.
• Prevents tiles from moving while curing.
• With the ATR system you only need 1 cross spacing plate for 4 tiles NOT 4 Clips like every other leveling systems.
Very easy to learn and use at any skill level - 5 Easy steps:
1. Screw spindle into spacing plate until screw tip is just visible at underside of plate.
2. Insert Tile Levelers spindle with spacing plate attached in between two tiles.
3. Lay adjacent tiles until all four corners, or two corners for the edge spacing plate are met.
4. Tighten spindle clock wise firmly until all four corners are lifted flush.
5. Remove spindle once tile adhesive is dry.
ATR Tile Leveling System
