Introduction: Make a Longboard Bearings Cleaning Kit Under $5 in 9 Easy Steps
About: Online Longboards Skateboard store with Quality boards and friendly service. Great selection of completes, decks, trucks and wheels. Pintail longboards, Cruiser boards, Drop Down or Kicktails we have it. For …
You can easily make a bearings cleaning kit yourself with materials you might have already at home for a fraction of the cost of store bought bearings cleaning kits and you can make under 10 minutes.
Cleaning your longboard bearings is a necessity to keep them smooth. You will ride much better with clean longboard skateboard bearings.
There are bearing cleaning kits out there you can buy such as Bones Bearings Cleaning kit or Oust Bearings Cleaning Kit for around $15, but with cheap or free (recycled) materials you already have - you can make one yourself. Best of all, you can use it over and over again. The kit is also great for skateboard bearings.
Step 1: What You Need to Make Your DIY Bearing Cleaning Kit
Small plastic bottle with a wide enough lid (sample: small Gatorade bottle) = recycle
Cheap ballpoint casing = one you have lying around
Scissors = you have already
¼” washer = $0,11
2 x ¼” nut with coarse tread = $0,28
¼” x 6” Bolt with coarse tread = $ 0,46
O- ring that fits around the bolt (like 1/16” OD x ¼” I.D x 3/32 O-ring) =$0,22
Step 2: Step 1. Cut a Small Hole
Take off the lid from the bottle.
Cut a small hole in the lid that will fit your bolt. You can use a scissor and punch it in.
Step 3: Step 2. Add the O-ring
Slide the O-ring on the bolt all the way to the top. This prevents leaking. You can find an O-ring in the plumbing department at home improvement stores.
Step 4: Step 3. Put the Bolt and the Lid Together
Slip the bolt through the hole.
Step 5: Step 4. Add the Washer
Take your washer and slide this all the way in the lid.
Step 6: Step 5. Add the Nut
Put on your ¼ “ nut and screw it all the way to the lid. This will hold everything in place.
Step 7: Step 6. Cut the Pen Casing
Take your pen and disassemble it. Cut or saw spacers from the outside of the pen. You can do this with a handsaw, sharp scissors or a crafts knife. Sand it a little to get the rough edges off if necessary. You can wing the length. Just don’t make it too long. You need to be able to cut 9 spacers out of the pen. If it is easier, you can add lines on the pen with a sharpie before cutting it.
Step 8: Step 7. Add the Bearings and Spacers to the Bolt
Now take the spacers and 8 bearings and put them onto the bolt, alternating from one bearing to one spacer.
Step 9: Step 8. Place Wing Nut
Place the nut at the end of your bolt.
Step 10: Done!
Your DIY Longboard Bearing Cleaning Kit is ready for use!
If you are looking for longboard bearings or need more info go to http://longboadsusa.com
