Introduction: Make a Square Knot Hemp Belt
Make a awesome hemp belt!
Step 1: What You'll Need
What you'll need :
hemp
belt buckle
scissors
hemp
belt buckle
scissors
Step 2: Prepare
Prepare :
Cut 4 strands of hemp about 6 times the length you want your belt to be. It's always better to get more than you need. Cut the belt off of the buckle. Then attach a strand to the buckle by folding it in half. Put the loop under the buckle and pull the ends through. Repeat with another strand.
Step 3: Knot!
Tie a square knot around each of your "home" strands. Then use the 4 middle strands to tie a square knot. Keep switching back and forth between outside knots and middle knots. [You can also add beads!] Just keep going!
Disclaimer : I did not go over how to do a square knot in this Instructable.
Step 4: Finishing
Finishing :
When you're ready to finish the belt. Make a big square knot using all of the strands you have. Use the 4 middle strands as your middle piece and two strands on each side to tie the knots.
Whenever you want to stop, tie a knot (jump a normal one =P) then cut the excess off.
Tada! Totally wearable hemp belt!
