Introduction: Make a Collapsable Table for Concerts in the Park!
About: I'm an environmentally conscious experimenter who loves to bring people together, build things, and when possible...blow things up! See us on YouTube too! https://youtube.com/WildmanTech
We saw this table, currently offered by Crate & Barrel, at concert in the park. We couldn't resist cloning it.
UPDATE! I've written another Instructable for a carry bag for this table here.
Step 1: Bill of Materials
1 ea. 48" x 7/8" wooden dowel
3 ea. 2" x 1/4" x 8' hardwood lattice
1 ea. 1" x 1/4" x 8' hardwood lattice
4 ea. 1/4-20 x 1" Carriage bolts
4 ea. 1/4-20 brass threaded insert nuts
4' x 1" nylon web belt
1/4" staples
Step 2: Cut the Dowel
Begin by cutting the dowel into four equal length pieces. Notice that I didn't say 12" pieces. This is because I have not seen a 48" dowel that was actually 48" long in recent years.
Step 3: Cut the Lattice
Cut the 2" lattice into 24" pieces. You'll need ten of them. I suggest trimming the whole stack at once to make sure they are all of equal length. Be very careful doing this. I used a chop saw and clamped the whole stack to the fence to keep it from shifting.
You'll need two 24" pieces of the 1" lattice too.
Step 4: Sand the Ends
Sand the ends of the dowels and planks.
Step 5: Burn the Nylon Belt
Cut two 24" pieces of nylon web belt and burn the ends with a lighter to keep it from fraying. This is a handy tip when working with nylon cloth too.
Step 6: Line Up the Planks
Line up the planks using a scrap of the lattice as a spacer to make sure they are spaced evenly. If one side is nicer than the other, place the nicer side down at this point because we are looking at the bottom.
Step 7: Staple the Belt to the Planks
Make sure the staples are shorter than the thickness of the wood and staple. My stapler isn't very strong so I had to assist it a little...with a hammer. Also pay attention to the surface you are working on because when I tapped the staples with the hammer it marred the other side a little.
Step 8: Continue Installing Planks
Continue installing planks making sure to move your spacers and keep the web belting pulled snug.
Step 9: Drill Some Holes
Lay the 1" planks across the table top and drill 1/4" holes in the corners. These 1" planks are spreaders to keep the nylon web belting taut. Enlarge the holes in the tabletop to receive the square head of the carriage bolts.
Step 10: Install the Spreaders
The table top should look something like this.
Step 11: Make the Legs
Using a straight edge and a scribe, mark one end of each dowel in the center. Clamp the dowel into a vise and drill a 5/16" hole 1" deep into the end. Note the cardboard wrapped around the wood to protect it from the vise jaws.
DO NOT HOLD THE WOOD IN YOUR HAND WHILE DRILLING!
I suspect there may be a jig for this, but I didn't have one so my holes may not have been perfectly centered.
Step 12: Install the Threaded Inserts
These brass threaded inserts are very delicate and difficult to install squarely. A couple of mine broke, but the inside thread was still good so I didn't have to make new ones. I suspect there's a special tool for this too.
Step 13: Put It All Together
From here, just screw the legs onto the carriage bolts and filp it over.
When you take it apart it rolls up into a handy little bundle.
You can apply a finish if you like. I often use olive oil or brown Kiwi Brand wax shoe polish.
Don't forget to make the Carry Bag too!
