Introduction: Making Your Own Auxilary Cable
With 2 headphones tape and some time you can make your own aux cable for your car, stereo, computer, Tv there are a lot of uses
Step 1: Decide on Your Headphones and Splice the Cables
First you have to decide on our headphones.
When deciding make sure both cables have the same criteria
The both have the same # of Cables on the inside either 3 or 4
They both work
Your willing to destroy them
Now choose how long you want each end and cut. Then strip the wires by using a wire stripper or scissors.
They both work
Step 2: Burn the Strings in the Wires (if Necessary)
Once you strip the cable you may notice that there may be fuzz covering the wire if there is it will be necessary to burn it away for it to work (trust me i know)
Step 3: Connect the Wires
This step is fairly easy there are 2 ways to do this
1. Twist them together and tape them
2. Use a bit of solder to connect them
After you decide how you will connect them connect the wires together (if your using shrink tube to keep it together put it on now)
Connect all colors to the corresponding color on each side
make sure they do not touch or they will short.
Step 4: Cover It Up
Now cover the wires using the shrink tube you put on or some electrical tape.
Cover each wire and make sure they don't touch each other or they can short
Step 5: Does It Work? and Conclusion
Does it Work? Of Course!!
All in all this is an inexpensive and possibly free way to have a nice long aux cable. And logically thinking nothing says you cant use 3 or more cables. So thanks for viewing!! But this isnt the best quality ever but its okay.
