Introduction: My Leather Arrow Quiver
hay there.
a few months ago a made a back quiver that i wanted to share with you guys. as a "traditional" archer(flat bow) i really like having my arrows on the back. yet i don't want a quiver that you have to pull up after a few times of shooting in order to even reach your arrows. because its made of one piece it really hangs on your shoulder so it keeps the same place pretty much all the time.
this "design" is made out of a single piece of leather, using leather straps to sew the quiver together and to make the chest piece looking better. as reinforcement of the quiver itself i put 2 cleaned welding electrodes(1 was way to short) in the sewed part. this way the quiver stays in shape if there aren't any arrows in it, this helps a lot when putting the arrows back in again.
i used a piece of rope(not para cord, don't have any) with the Salomon bar to complete the circle.
whole process took me about 3/4 hours, you can do it pretty fast if you get the hang of it.
materials:
leather for quiver/chest piece
large piece of leather to cut the straps for the sewing
scissors
an awl or another way to make the holes(i used a squared awl, strips are pretty broad)
2 welding rots, or any other metal that is strong enough and still thing enough
a piece of cordage
Brains
optional:
tape(masking tape), you can use it to hold the leather in place while you sew it. this way you can keep the shape. just rip off like 10 centimeters when you are near the edge and you can continue
a few tips for people who are going to do something similar:
when using leather straps, cutting one end to some kind of needle shape will help a lot for getting trough the holes. if there is a small piece trough it you can use a leatherman or other pliers to pull it all the way up.
you are likely to have to trim some pieces before you can make a nice end product. just be wary, don't cut to much at the same time!
using an awl can hurt if you use your fingers to press against. be smart using one!
sewing the straps tight together will look much better then all the gaps between it. dont stick the awl somewhere, think where it would look close to the best.
materials:
scissors
a piece of cordage
Brains
optional:
