Introduction: No Heat Headband Curls (over Night)
Are you sick and tired of dry damaged hair because you have to use heat well this is the hair style for you! These heatless curls are bouncy and add volume to your hair with out damaging it. It's so comfortable that you can sleep in it! Your friends will ask you how it got so curly and you can tell them with a headband!:)
Step 1: Things You'll Need
-damp hair
-head band ( the ones that are stretchy)
-small hair clip
-comb/brush
-about 8 hours
Optional
- hair spray
- mousse
- styling gel
- bobby pins
-small hair clip
-comb/brush
-about 8 hours
Optional
- hair spray
- mousse
- styling gel
- bobby pins
Step 2: Take a Shower
Take a shower and wash your hair. Your hair needs to be clean and free of dirt or other bacteria on your scalp.
Step 3: Brush Your Hair
After your shower brush your hair making sure it's still damp this is the time when you can apply mousse or other hair products. IF YOU USE STYLING GEL WAIT TILL STEP 10!
Step 4: Grab Your Headband
Put your head band on hipster style.
Step 5: Wrapping Your Hair
Take a small piece of hair about an inch in width from the front of your hair. Repeat on other side of head.
Step 6: Wrapping Continued
Then take that piece of hair and wrap it around the head band like in the picture. Repeat on other side of head.
Step 7: Almost Done
Take another small piece of hair with the other piece you just wrapped around the head band and wrap it too. Continue doing this till you get to the back. Repeat on other side of head.
Step 8: The Back
Once at the back of your hair there should be two large pieces of hair. One on both sides of your head .Take those and slowly wrap them around the back part of the headband.
Step 9: Hair Sticking Out No Problem!
Take a bobby pin and pin down those stubborn hairs!
Step 10: Styling Gel
If your hair tends not to stay curled then apply styling gel to the wrapped part of your hair.
Step 11: Holding It in Place
Take the small clip and clip the back of your hair to hold it in place. You could also use a silk or satin shower cover and put that on as well to hold it in place.
Step 12: Go to Sleep
Get some beauty rest!
Step 13: Unwrapping
Remove the clip we put in the back. If your hair is wet no worries! The wetness of the hair will keep the curls together more! When you wake up slowly unwrap the hair that you set in place the night before. Don't tug on your hair! You could ruin the curls if you tug on them to hard!
Step 14: Hair Spray
Proceed to style as normal but if you use hair spray for this style only use about 2-4 sprays this style holds pretty well on its own.
Step 15: Show Off Your New Curly Hair Style
Show your friends! :) Enjoy!!
