Introduction: Origami Paper Bowtie
I may have found the perfect accessory for that fancy Near Year's Eve party you are going to! Yes, look totally dapper with this bowtie made entirely out of paper. It's sophistication with a twist.
PS I can't promise that this DIY is super easy. This video is not to necessarily teach you how to make each fold, but to demonstrate the general crease pattern. If you don't have a lot of experience with folding tessellations, I'd strongly suggest that you try the bracelet DIY first. It will help you get a sense of how these folds work. Good luck!
Here I am using Canson Mi-Teintes drawing paper, but anything around 98 lb (160 gsm) should work.
o Bowtie Template: http://goo.gl/MCDLyY
o More Info: http://goo.gl/vaEDYr
o Bracelet DIY: http://goo.gl/vaEDYr
Designed by Fiber Lab
o Website: http://www.fiberlab.ca
o Etsy: http://www.fiberlab.ca
o Facebook: http://www.fiberlab.ca
Step 1: Step 1: Video Instruction
Step 2: Photo Step 1/17
Print the DIY crease pattern on letter size cardstock.
Step 3: Photo Step 2/17
Cut out these three pieces: two bigger pieces for the bow, and one for the knot.
Step 4: Photo Step 3/17
With the ruler's straight edge as guide, score along all the dot-dot and dash-dot lines with the dull side of a blade. This will allow easy folding. Be careful to not cut through the paper.
Step 5: Photo Step 4/17
Fold the bow strip like so.
Step 6: Photo Step 5/17
Step 7: Photo Step 6/17
Start following the crease lines to make the mountain and valley folds.
Step 8: Photo Step 7/17
Crease these folds.
Step 9: Photo Step 8/17
Squeeze to set the folds.
Step 10: Photo Step 9/17
Crease and set the next group of folds.
Step 11: Photo Step 10/17
Step 12: Photo Step 11/17
Now you have completed one side. Repeat for the other side.
Step 13: Photo Step 12/17
Now you have completed half of the bow. Repeat and make the other half bow.
Step 14: Photo Step 13/17
Crease the knot strip like so.
Step 15: Photo Step 14/17
Flatten the knot strip and create this pleated look.
Step 16: Photo Step 15/17
Make it into a loop.
Step 17: Photo Step 16/17
Glue the two half bows together.
Step 18: Photo Step 17/17
Wrap the loop around the bow. And you are done!
