Introduction: PVC Chicken Feeder
About: Warthog-faced buffoon.
We wanted a lot from our chicken feeder: it had to be easy to fill, hard to spill, safe from non-chicken life forms, weather resistant, easy to make, and inexpensive. We tried a number of other designs that worked to varying degrees, but this was the only one that did all we asked it to. Enjoy!
Step 1: Trial and Error
There are lots of PVC chicken feeders out there, and several folks have gone with a design very similar to this one. But I haven't seen the extra three-inch piece added to the Y connector: without that small extension the chickens managed to spill quite a lot of food, but that three-inch piece cut spillage to almost zero!
We tried a 180-degree elbow with the edge cut off: the birds were able to eat just fine but they spilled quite a lot, and closing the pipe for waterproofing and rodent-proofing would have required additional engineering. We considered quite a few other variations, but they all had drawbacks; mostly related to spillage and security.
At first the bottom part connected to the "Y" was only three inches long and the birds didn't like that much, so we set it up on a brick and the chickens seemed to like the altitude better, so the final version uses a six-inch length of pipe to place the food where the chickens can easily reach it.
Another way to go (and in response to some reader comments): if you add some kind of plug right at the bottom of the Y, the birds would be able to reach all the food. It will take you more than 3 minutes to assemble, but it would be more efficient. Of course, it's best to use plastic or something else that can be thoroughly cleaned. Most of the plugs I see out there would work, but you'd be back to the height problem (if you're concerned about chicken ergonomics). Easy to fix: just mount the feeder higher. Or: run a long carriage bolt through the base cap (or plug), letting the end stick out and hit the ground, like the spike that sticks out of the bottom of a stand-up bass or cello.
Step 2: Materials, Tools
We settled on three inch PVC pipe: two or four would work, too. The pipe itself normally comes in 10-foot sections, so you can get one of those and make at least three feeders using these dimensions.
-Three inch diameter pipe: 20 inches long. Or more. Or less.
-Three inch diameter pipe: 6 inches long
-Three inch diameter pipe: 3 inches long
-45-degree "Y" connector, like this, but this would be quite cool, too.
-Two three-inch PVC caps, like this.
-Hacksaw
-PVC cement
Step 3: Assemble
Assemble according to the image, following the tiny instructions on the label of your PVC cement. Glue only the three pieces that touch the the "Y" splitter and the bottom cap.
That's it.
You're done.
It only took like three minutes, didn't it?
Let it cure for 24 hours, or until it is no longer stinky.
Actually, you can get by without gluing at all, as long as you're careful when filling and moving: it would be no fun if the bottom cap fell off of a full feeder during transport! But then it would only take like a minute and a half to build, right?
Step 4: Enjoy!
Remove the top cap to fill using a funnel, bungee the feeder to something, and invite the birds!
Place the cap over the opening at night to make the feeder weather- and critter-proof.
UPDATE: To add awesomeness, do what Flodado did:
https://www.instructables.com/id/PVC-Chicken-Feeder-with-Meter/
Cheers!
