Introduction: Plants in Bottles
About: I'm a teenager in England who likes to do all things creative. I love tinkering with electronics and I happen to be one of those people whose life to-do list always grows, even if I try hard at doing the thing…
These plants in bottles are essentially DIY terraria in bottles. They look quite good and are very simple to make with whatever bottles you might have lying around. I made these one afternoon with my cousin and he really enjoyed it!
Obviously, this is not the first terrarium-themed instructable. Inspiration came from noahw's DIY Terrarium instructable, along with ThinkLem's Lightbulb Terrarium and alisha145's Tiny Terrariums. However, I think the wine bottle idea might be a first!
Step 1: Bottles
Go out and get some bottles. I found some nice looking ones in our recycling box at home. Mix and match if you want to; or you could go with all the same bottles. Jam (jello if you live over the pond) jars also work as does pretty much any other glass receptacle.
Your bottles will probably needs the labels removing. Labels are either stuck on with water-based or solvent-based glue. Unfortunately one needs a lot more work to remove than the other.
Start by soaking the bottles in hot water (but not boiling hot as this could crack the bottles) for a few minutes. Labels glued on with water-based glue will either soak off in this time or some gentle pushing with a paint scraper will do the trick. For labels stuck on with solvent-based glue, scrape away as much of the paper as possible (ideally all of it) and give the bottle a rinse. To remove the gummy residue from the solvent-based glue, I used acetone (it's also in nail varnish remover but less concentrated). Practically anything that will dissolve plastic works, although you could just buy some de-gluing stuff from your local hardware store.
Step 2: Drainage
Because the entire habitat for the plant will be enclosed in the bottle, you need some sort of drainage to stop the earth/compost going soggy and mouldy and also so as to not drown the plant.
I used some gravel (from the drive) and some builders' sand we had lying around. The gravel creates a reservoir in the gaps between the stones whilst the sand stops the earth from falling into the holes.
You want a decent amount but not too much (about 2 inches or 5cm), bearing in mind that you need to add earth and that there needs to be enough room for the plants to grow.
Step 3: Compost
Your plants will need something to grow in. I used standard compost. Earth from a garden would also work. You should sieve whatever you are going to use as earth from a garden contains lumps and so does compost (admittedly smaller lumps though). Because the amount of compost you need is so small, these lumps would be very visible inside the bottles. The bigger ones won't fit down the bottle neck and will block a funnel, which is annoying!
If you plan to use seeds, leave some of the soil out so you can cover them after the next step. The same also applies if you are using small seedlings or plants.
Fill your bottles with about 2-3 inches (5-7.5cm) of soil. Give it a slight shake or tap to level it out.
Step 4: Planting
You now need something to plant inside your bottles. I am told that herbs work quite well and that they may even adapt to the size of their environment i.e. stay small if they're in a small space (like a bottle).
Seeds
For seeds, just sprinkle a few into the bottle and cover with a little extra compost.
Seedlings
These can be difficult, and so there are a number of different approaches:
   1)   If you have some very long tweezers or other similar instrument, you can simply push their roots down into the soil.
   2)   If their roots came in a block of soil, you may be able to get the block of soil inside intact, and then you can fill around it with compost. In this case, you should do this just after adding the sand to leave enough room for the plant to grow.
   3)   If you feel adventurous, you can drop the seedlings straight in and add more compost on top. It is highly likely that this won't work or will look very ugly, but mother nature may sort things out (eventually).
Tree Saplings
We also made a bottle with an ash sapling that we found in the garden. It was quite big which was a bit of a problem and so we added it right from the start which in hindsight was probably not such a good idea. Tree saplings will vary so I leave you to discover a method that works for your bottles and the size of whatever tree sapling you happen to have.
Step 5: Care
A bit of water is needed now - a spray mister works well as it will cover the compost evenly. The compost needs to be damp and it's good to have a little water in the bottom as well.
The bottles won't need much watering over time as the relatively closed nature of the bottle means that most of the water will cycle back. A bit of plant food every now and then might help as the nutrients in the compost will be limited. Make sure that whatever plant food you use is suitable for what you've planted though.
Now it's time to sit back and watch your plants grow!
