Introduction: Program an ATtiny With Arduino
Follows are directions for programming the ATtiny microcontrollers using the Arduino IDE. In plain English, this is how to program 8-pin Atmel chips as you would normally an Arduino. This is cool because the ATtiny is tiny, and - well - this allows you to make tiny things that don't need a big ol' microcontroller.
The instructions I have posted here are pretty much the same as instructions given by the incredibly awesome High-Low Tech Tutorial. I posted my version of the instructions here because I plan to make a couple of upcoming projects using ATtiny chips and figured I would show my process.
Step 1: Go Get Stuff
You will need:
- Arduino
- Breadboard
- ATtiny85 (or ATtiny45)
- 10uF electrolytic capacitor
- 220ohm 1/4 watt resistor
- LED
- hookup wire
Please note that some of the links on this page contain Amazon affiliate links. This does not change the price of any of the items for sale. However, I earn a small commission if you click on any of those links and buy anything. I reinvest this money into materials and tools for future projects. If you would like an alternate suggestion for a supplier of any of the parts, please let me know.
Step 2: Wire the Circuit
Connect the Arduino to the ATtiny as follows:
- Arduino +5V ---> ATtiny Pin 8
- Arduino Ground ---> ATtiny Pin 4
- Arduino Pin 10 ---> ATtiny Pin 1
- Arduino Pin 11 ---> ATtiny Pin 5
- Arduino Pin 12 ---> ATtiny Pin 6
- Arduino Pin 13 ---> ATtiny Pin 7
Step 3: Program the Arduino
Select the "ArduinoISP" sketch from the "Examples" menu.
Upload the sketch to your Arduino as you would any other sketch.
Your Arduino is now configured as a serial programmer that can program other chips.
Step 4: Filter Cap
Put the 10uF capacitor between ground and the Arduino reset pin. Make sure to keep an eye on the capacitors polarity (ground to ground!).
It is rumored you only need this for the Arduino Uno, but I have found it helped matters to include it with earlier versions as well. If you find that it is not working in the next steps, simple remove it and see if that helps.
Step 5: ATtiny Core Files
Take note of your sketchbook folder from the Arduino preference menu.
Create a new folder in your sketchbook folder called "hardware"
Then, go to this page and download the file: attiny45_85.zip
Unzip this file and leave it in the new hardware folder.
Finally, restart the Arduino programming environment. The new cores should now be loaded.
Note that there are also core files for a number of other ATtiny chips. This page is a good starting point for interfacing with a wide range of them using the Arduino.
Step 6: Program the ATtiny
Select from the top menu:
Tools --> Board --> ATtiny85 (w/ Arduino as ISP)
(Of course, you will want to select a different chip for this if you are using one.)
Then open the basic blink example and change the pin number from 13 to 0.
Finally, upload it as you would any other sketch.
It should give the following error twice:
avrdude: please define PAGEL and BS2 signals in the configuration file for part ATtiny85
Simply ignore the error message and you should be good to go.
Step 7: Test Circuit
Connect a 220 ohm resistor to pin 5.
Connect an LED between the resistor and +5V.
It should blink.
Congratulations. You're done.
Did you find this useful, fun, or entertaining?
Follow @madeineuphoria to see my latest projects.
4th Epilog Challenge
